09 5.3 dod delete
when doing the dod delete, what to do with the dod plug, does it need to be plugged in to run on 8, or will it run on 4 until the pcm is flashed? new cam, correct lifters etc. thanks.
leave the plug unhooked.
the tune will shut off the 4 cyl mode replace the lifters with new ls7 replace the valley cover with a non-dod one. like an ls3 style Texas speed has kits for what you need. |
4.8 valley cover will work also and is cheap
