07 vortec max nbs what cam/engine mods?
Old Apr 18, 2016 | 06:08 PM
Makaveli07's Avatar
Default 07 vortec max nbs what cam/engine mods?
hey i have a 07 silverado vortec max new body style the head gasket just went on it so im going to get the motor built but i have no idea what parts to use...right now the truck has a blackbear tune, volant intake, speed engineering 1 7/8" headers with true 3" duals with xpipe and a built transmission with shift kit, corvette servo 3300 stall torque converter etc. im looking to make as much power as possible but the truck is still daily driven...can anyone recommend a good vvt cam? and what else should i upgrade while im in the engine im gonna do lifters and springs but i dont know much about modding engines so i dont know what else i can do?
Old Apr 18, 2016 | 06:26 PM
Vortec350ss's Avatar
Your truck doesnt have VVT in it.
Head work on the L92 heads will show gains, but not as much as prior generation heads do. I would probably send them to Advanced Induction for a port job if I was you. Mill them slightly to give yourself a tad more compression too. How many miles are on them? You will want to make sure you stick with powdered valve guides ad the bronze guides will get abused by the stock rockers.
From there basic cam and valvetrain upgrades are in order. You will need to replace the DOD lifters with a standard LS7 lifter from GM.
There are a lot of cams that will work great for you. The 3300 converter opens up a lot of options. You can very easily pick a cam with will make more torque at 3300, but also pull like a freight train above 5500 compared to stock.
What kind of manners are you looking for? Post up a video of your desired idle quality and we can go from there. How about target shift points?
What do you think of this?
Old Apr 18, 2016 | 07:12 PM
Makaveli07's Avatar
That sounds good i wouldnt mind a more lumpy cam and not sure on shift points if it makes alot of power at higher rpm would i want it to shift higher for max power? And the truck has 170k on it and im in canada so i dont really wanna send the heads out should i just keep them stock if they flow good? I do have a local guy thats built drag cars for 30+ years and he said he could port the heads and id save alot of money not shipping them out of canada
Old Apr 18, 2016 | 07:18 PM
Makaveli07's Avatar
And do you know what other parts i can upgrade in the engine/heads while its apart?
Old Apr 19, 2016 | 06:59 PM
Makaveli07's Avatar
And from everything im reading my 07 has vvt its the square body style not a classic it has the l76 engine
Old Apr 19, 2016 | 08:35 PM
It has DOD and not VVT. Only the L92 had VVT in 2007.
Old Apr 20, 2016 | 05:47 PM
Makaveli07's Avatar
If my truck has a sensor between the water pump and crankshaft pulley does it have vvt? Thats what the guy told me at a shop i brought it to and mine has a sensor there.
Old Apr 20, 2016 | 06:26 PM
Makaveli07's Avatar
Just found a link showing vvt vs non vvt front cover and my truck has vvt the cover sticks out its not flat like the non vvt cover
Old Apr 23, 2016 | 08:24 AM
1994Vmax's Avatar
Yeah that info he said isn't correct. All of the L76's in the trucks had VVT... just the car version of the engine did not. Another LS with VVT in 2007 is the LY6 used in the HD trucks.
Old Apr 23, 2016 | 09:02 PM
Wolftrk99's Avatar
What rpo code engine is in the truck??? That will tell whether its vvt or not and even the earlier non dod engines had dod hardware
01SilveradoJakee
11
May 30, 2016 09:17 AM
OneBadSSS
Mar 31, 2016 09:13 AM
Jonblarc7
Mar 20, 2016 10:17 PM
blownss27
Mar 3, 2016 01:42 AM
kazfan30
Feb 22, 2016 01:42 PM
