02' LS6 camswap 5.3L what to do about pushrods.
Old Jun 26, 2008 | 05:37 PM
Default 02' LS6 camswap 5.3L what to do about pushrods.
I changed the valved springs and installed the cam this is on an 03 I am tinkering on. I have heard so many different opinions I do not know what direction to go. The heads are bonestock and have not been milled any. So do I go with stock length a hair longer or what. I am for sure wanting to go hardened route as opposed to the oem's. By my way of thinking if anything the LS6's use taller valves so they can use standard length LS pushrods. Could I take the difference in valve height and then in turn add that to the length of the pushrods to make up the difference since the 5.3 truck valves are shorter.Any help is appreciated. Thanks
Old Jun 26, 2008 | 07:22 PM
hirdlej's Avatar
Get a pushrod length checker and measure.......
Old Jun 27, 2008 | 07:42 PM
I don't mind going the checker route but I figured somebody here was bound to know exactly what I would need since this has been done for quite some time already. Anyone have a canned this is what I need ..... Thanks
Old Jun 27, 2008 | 07:44 PM
Mangled03gmc's Avatar
Baltimore Whore
7.35 but but, you could prob get away with the 7.4's
John
Old Jun 27, 2008 | 10:42 PM
charcold-bowtie's Avatar
I went with 7.4, as have many. No problems or noise here. I think you jsut lose a few thousanths of preload in the rocker.
Old Jun 27, 2008 | 11:36 PM
LS6 Silverado's Avatar
I recently installed the Comp XR265HR which is very similar to the Zo6 cam and heres what i found. The Comp cam base circle was .055" smaller then my stock 5.3L cam, That would put the radius difference (pushrod length difference) at 27.5 thousandths (.0275" ) I milled my heads .025" to compensate for the difference (and to boost compression) and used stock length pushrods and everything went together exactly as it came apart (lifter preload etc). Have a scosh of valvetrain noise but not bad. Been told the Comp 918's are a bit noisy as they are so much stiffer than stock. I am pretty sure the Zo6 Cam is almost the same base circle .050" i believe. So that would put you at a difference of .025" So to retain stock valvetrain geometry you would need 7.425 pushrods. Just my two pennies-
Old Jun 28, 2008 | 04:00 PM
Thank you a bunch. after sitting down and doing the math. I came up with 7.405 being the difference. So 7.425 is perfect I just wanted to clarify I knew there had to have been a few guys that have done this. What are the stockers for length 7.4's?
Old Jun 28, 2008 | 07:07 PM
Sean01's Avatar
I just did a 02 ls6 cam in my 6.0 and went with the the 7.425's and the valve train is super quiet.
Old Jun 28, 2008 | 08:15 PM
2.6KB's Avatar
I used 7.425 and every worked out great
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Nov 6, 2015 07:42 PM
old motorhead
Sep 29, 2015 08:22 PM
JoshH
Sep 28, 2015 11:19 AM
zblee
Sep 19, 2015 06:33 PM
