02-04 z06 cam swap?
Old Nov 16, 2007 | 11:11 AM
WJ MARK's Avatar
Default 02-04 z06 cam swap?
Tryed a search didn't find much
What length push rods will I need, who has em for the best price?
what are avarage gains with this cam on a turbo truck?
Thanks fellas!
Old Nov 16, 2007 | 12:04 PM
kbracing96's Avatar
Stock rods WILL work, but to keep the same lifter pre-load, you need rods that are .025 (7.425) longer since the cam has a .050 smaller diameter base circle. Couldn't tell ya where to get them, since i didn't use them. The gains will be from mid to mostly upper rpm range. Instead of falling off around 5800, will pull hard to 6200+.
Old Nov 16, 2007 | 12:40 PM
WJ MARK's Avatar
You didn't have any issues with the stock length?
If I change them out should I go hardened?
You got the springs from SDPC right.
Old Nov 16, 2007 | 01:26 PM
kbracing96's Avatar
I didn't. It's up to you if you want hardened, might be more reliable in the long run, who knows...
yep on the springs
Old Nov 16, 2007 | 04:48 PM
quicksilverado's Avatar
If you're gonna swap the cam, throw some hardened rods in while its apart.
5.3Okasai
Mar 9, 2022 01:07 PM
OHsixLS3
Dec 27, 2016 09:30 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
lxcoupe
Jul 30, 2015 02:42 PM
Aboss
Jul 9, 2015 10:28 AM
