Towing with a 5.3
#31
Technically I could get a honda accord to pull 10k pounds.
But that's the whole point here, how well can I do that (will the drive line take it, will it damage it) and how safe will it be (can I actually stop it once I get it going and can I perform emergency maneuvers if needed)
Pulling anywhere near 10k with a half ton is not a wise plan in my opinion. Around 5k would be my limit. Can it be done? Yes.. but should it
tjmath (06-29-2020)
#34
#37
Yup. Half tons should only tow lawn mowers. This 6000lb trailer is keeping my truck in 4th gear going up and down the hill country trying to stay between 60-70mph and it’s no secret who the boss is between the truck and trailer.
But it is doing it and I don’t feel unsafe at all. Trailer brakes and tow haul are keeping everything in check. Coolant temps are 210* and trans temps are between 212-228*. When I get back from lunch I’m going to flip the ball so instead of a 2” drop it’ll be a 3/4” raise. Should help level the trailer out.
tjmath (07-03-2020)
00pooterSS (07-06-2020)
#39
I stopped using my 4" drop hitch and just went to a straight hitch for me. With no helper bags, shitty, warn out stock leafs, and a 6" lift I was sagging so much it was not enjoyable. Went to the straight hitch and it leveled the trailer out but still squatted the truck a good amount. Makes me really want a better set of leafs and a set of helper bags.
Then again I really don't know if I want to put a set of helper bags on it because eventually I want to do long travel and probably won't do much towing with it at that point.
