Safe AFR for DI Motor w/ Boost
Old Jul 20, 2014 | 06:29 PM
  #31
smokeshow's Avatar
Mod with training wheels
Originally Posted by smokeshow
With port injection, a good portion of the fuel doesn't even have any positive contribution to the actual combustion. When you richen it up to 11.5 AFR on gasoline, basically all of the fuel added between 12.5 and 11.5 is for knock prevention. During the compression stroke, that additional fuel is vaporizing, absorbing heat from the compressing air and metal surfaces in the cylinder. It also serves to slow the combustion down to make sure your peak cylinder pressure occurs at a certain crank angle to maximize torque on the power stroke.
When the fuel is direct injected, it doesn't need to be injected in surplus to absorb heat. All it needs to do is do its job in combustion and that's it. So a lot less fuel is needed. Like Area57 said, the optimal range to shoot for is high 12s AFR. 12.8, plus or minus 0.3.
For anybody concerned about the validity of my statement, here are 5 sources for the information:
Fuel Trim Info - Ross-Tech Wiki
O2 sensors as a tool
E85 max power ratio questions
FUELS DATA
Air
Just to make sure this is perfectly clear, these values hold regardless of the amount of boost or lack thereof. However, something critical to keep in mind is when the injection begins with respect to crank angle. Since it is not a diesel and doesn't use compression ignition exclusively, fuel must first be allowed to disperse in the cylinder prior to firing the spark plug. So, the injection event must precede ignition for this to occur. With that said, its obvious at this point that you have fuel in a hot, increasing compression environment. What does this mean? There still exists the potential for preignition! Hence why the genius above states that he started seeing knock on his DI truck as he was leaning it out. Unless gas engines someday utilize compression ignition, the potential for preignition will continue to exist. Therefore, additional enrichment for the purpose of knock prevention will still be necessary.
Always make sure you get someone knowledgeable to work on your vehicle's tune, or if you're doing it yourself, make sure you read about it A LOT. A good foundation knowledge is crucial to getting things to work properly. A great example of this is about 6 months ago when supercharged680 (a member on this site that I built a truck for and shipped overseas) came to me about issues he was having with his truck not running quite right about a month after it got there....torque bucking at cruise, down on power, etc. He sends me the tune and it turned out that our fabulous thread contributor ayousef here had raped the **** out of it. It wasn't even the same tune, but some hack job that was thrown together I surmise in an attempt to prove to his friend that he knows something. I had supercharged680 put the original tune back in and the truck suddenly ran fine! It would seem that ayousef made quite a fool out of himself trying to tackle a complicated task with such elementary knowledge on the subject. I would advise everyone to take everything this clown says with a ******* block of salt.
Old Jul 20, 2014 | 06:34 PM
  #32
ayousef's Avatar
You made a fool of yourself, bro. I got rid of your dumb *** because I get tired of explaining things to idiots who think they are right regardless of the information presented to them. You can lead an ignoramus to knowledge, but you can't make him think.
Furthermore, no ad hominem has occurred at all here. Might want to work on your knowledge of logical fallacies. Here's a quick lesson for you...this is called the genetic fallacy:
You are wrong and ******* retarded because you think magical evil genies possess your friends.
While that most certainly is a genetic fallacy, lets be real here: how in the **** is anybody supposed to take you seriously when you're so prone to believing things that would get you put in a psych ward? For anybody reading...yes indeed, that is what this clown believes.
I will have a discussion about the science behind engines, but I will NOT debate with someone who simply debates for sport.
lmao, you deleted me because I bashed you in front of all your facebook friends when you claimed that you cannot measure restriction using boost pressure.
Also, incase you don't understand what an ad hominem attack is, calling me an idiot, a fool, a clown and ******* retarded instead of adding any useful information to the discussion is as classic as is gets of you.
but im not the one getting butthurt here, you are claiming to know **** about direct injection engines without even having tried or tuned a FI direct injection engine nor owned one, you cant run as FI direct injection engine at 12.8:1 AFR but what do you know ive seen your shitty tune on Ahmad's truck, don't make me show the world how it looks like Mr. tuner engineer.
Old Jul 20, 2014 | 06:37 PM
  #33
ayousef's Avatar
FUELS DATA
Air
Okay lets call supercharged680 into the discussion. and post your tune and my tune. Your tune which runs at 10.5:1 afr while it commands 14.5 afr, calls my tuned hacked lol.
Old Jul 20, 2014 | 06:44 PM
  #34
smokeshow's Avatar
Whose tune ran correctly? The enrichment in my tune was handled by the methanol injection....if you didn't know, there was a lot of it. Making the numbers look ideal in the tune doesn't make it work correctly. When you decreased the VE values to add in fuel through the power enrichment, the PE might have suddenly looked fancy....but you just pulled about 25% line pressure from the transmission. And you never changed shift pressures in the trans. So not only did your hack job run like ****, you set your friend up for a burned up transmission. Good job, **** stick.
Old Jul 20, 2014 | 06:46 PM
  #35
smokeshow's Avatar
Again, with the debating for sport. You get proved wrong over and over and try to perpetuate this by bringing up more bullshit for us to call you out on. Why don't you try actually spending time learning about this stuff instead of being a **** sucker who just likes to argue?
Old Jul 20, 2014 | 06:55 PM
  #36
smokeshow's Avatar
There was no bashing. There was me trying to explain things to an idiot, and I got ******* sick of it. If you think that is what I 'claimed' then you did not understand the conversation at all. Typical of someone to attempt to refute something when they don't even understand it. I see it from anti-evolutionists all the time.
No, dumbass....that's called an insult. Telling you that you are wrong because you are a dumbass...now THAT is ad hominem. You just don't get it. As for the useful information in this discussion....um, see the useful information that I have posted. LMAO
Hey now, that's genetic fallacy! Good job, you're learning! As for running 12.8:1....once again, have a look at the information I have posted AND referenced. Do you read? My tune was the one that got his truck running mid 10s on old street tires right off the boat....yours is the one he called me complaining about. LOL
Old Jul 20, 2014 | 07:02 PM
  #37
Atomic's Avatar
I have a gauge for that
I believe my fun meter has been pegged for this one. If you two would like to continue the conversation feel free to do so via PM or facebook.
TXsilverado
Nov 26, 2015 10:54 AM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ls3silverado
Jul 31, 2015 04:22 PM
silver-mod-o
Jul 27, 2015 05:24 PM
