Safe AFR for DI Motor w/ Boost
Old Jul 18, 2014 | 11:21 PM
  #21
ayousef's Avatar
Originally Posted by smokeshow
With port injection, a good portion of the fuel doesn't even have any positive contribution to the actual combustion. When you richen it up to 11.5 AFR on gasoline, basically all of the fuel added between 12.5 and 11.5 is for knock prevention. During the compression stroke, that additional fuel is vaporizing, absorbing heat from the compressing air and metal surfaces in the cylinder. It also serves to slow the combustion down to make sure your peak cylinder pressure occurs at a certain crank angle to maximize torque on the power stroke.
When the fuel is direct injected, it doesn't need to be injected in surplus to absorb heat. All it needs to do is do its job in combustion and that's it. So a lot less fuel is needed. Like Area57 said, the optimal range to shoot for is high 12s AFR. 12.8, plus or minus 0.3.
are you referring to forced induction DI AFR's ? If so I would have to disagree based on my personal experience with those engines. If you're comparing two indentical engines: a) port injected motor vs b) DI motor, then you could probably lean out the DI motor just a tiny bit over the port injected motor due to the reasons you mention, HOWEVER car manufacturers already took advantage of direct injection not by leaning out fuel mixtures but by bumping up compression ratios, so in essence you cant really run leaner air fuel ratios with any decent amount of timing, and by decent I mean 15 degrees on a bone stock ecotec 5.3 on 93 octane gas.
I have a stock 2014 5.3 truck and couldn't lean out more than 12.6:1 with about 16 degrees of timing on 93 without it knocking quite a bit, and this seems to be the norm if you look around.
Old Jul 18, 2014 | 11:30 PM
  #22
ayousef's Avatar
Originally Posted by Bass Mechanic
Not surprised to hear this, keep in mind on a DI engine the fuel is sprayed into an already closed and in compression cylinder.
As a result your adding 11.5 parts of additional fuel to an already full charge of air. The net result is in a way, your supercharging with the pressurized fuel. Even though it's richer you have more volume stuffed into the cylinder.
Compare that to multi port. Let's say for easy math a cylinder is 100 cc's your going to draw in at best 100 cc's of air and fuel.
With DI you get 100 cc's of air and your adding additional fuel on top of that already full cylinder. The richer you make it to a point the more total volume you have to ignite.
This is the same reason flex fuel engines that use DI make more power on e85 because your stuffing yet 33% more fuel into the same cylinder. It's nearly the same as adding 33% more air and fuel into the same space as a multi port and a small supercharger
Not to mention the additional cooling effect of spraying the fuel directly into the cylinder.
sorry too much wrong info here.
Old Jul 19, 2014 | 07:11 AM
  #23
Atomic's Avatar
I have a gauge for that
Ok mister engineering expert, care to correct the rest of the world with your vast knowledge?
Old Jul 19, 2014 | 07:21 AM
  #24
smokeshow's Avatar
Mod with training wheels
Lmao. That dude is a joke.
Old Jul 20, 2014 | 03:47 PM
  #25
ayousef's Avatar
Classis Ad hominem attack guys just classic, regardless of what you studied if you don't know what you're talking about someone with more knowledge on the subject will inevitably correct you.
Now intead of the name calling, why don't you let me and everyone else know why I am incorrect, show us what you studied engineering for.
For Atomic: You need to explain to everyone how you cannot have detonation without pre-ignition like you claimed in your previous post.
As far as Smokeshow is concerned I think I made enough of a fool of you on your facebook page, which is why you deleted me and added me 50 times in a row lmao, don't want you to get too butthurt on the forum as well.
Old Jul 20, 2014 | 04:21 PM
  #26
Atomic's Avatar
No, I dont need to explain anything. Your assumption is a burden of proof fallacy . It is up to you to explain why you are right and I am wrong, not mine to defend myself.
Old Jul 20, 2014 | 04:27 PM
  #27
03sierraslt's Avatar
Haha
Old Jul 20, 2014 | 05:13 PM
  #28
ayousef's Avatar
Well not exactly...detonation can come before the spark plug fires if preignition is soon enough. Detonation is when the stuff in the combustion chamber basically explodes and doesnt burn smoothly (deflagration). This usually happens when the mixture is ignited while the piston is still on the up stroke. Preignition may just mean the mixture starts to burn 1 degree sooner than expected. The hottest part of the chamber is usually the spark plug anyway, so it starts there like normal.
You can have preignition without detonation, but can never have detonation without preignition.
On the subject of compression ratio and DI....diesel fuel injection rail pressure is usually 15,000-20,000 psi while gas is usually 1500-2000psi. The difference has a lot of reasons; the volume of fuel required for diesels are higher (depending on how much coal you are rolling), the time required for diesel combustion is longer (hence the low rev range), the fuel itself is thicker (doesnt atomize as easily), and the compression ratio in addition to the boost diesels run makes it a much higher pressure environment to spray in to.
If you research diesel pre-injection where they pulse the fuel into the cylinder before the primary injection event, you can actually get real detonation in a diesel. Obviously this isnt the standard deal, but it is possible.
A big reason why DI gas engines have higher compression ratios is because they can get away with it....what I mean is if you can control precisely when the fuel is in there you can minimize the time it is allowed to hang out and could possibly auto-ignite. More compression means more heat, and heat is what ignites the fuel. So why dont gas DI engines have compression ratios similar to diesels (that are in the 18-20 SCR range)? Because the parts would have to be bigger to handle the stress (which adds weight), but more importantly the fuel would not be able to tolerate the heat in the chamber without preignition.
A big deal with DI engines is made about chamber swirl with piston design. The fuel air mixture needs to be as evenly distributed as possibly to limit excess lean or rich spots in the volume.
As far as volume of fuel injected of a comparable DI gas engine and a diesel of the same size, diesels usually run much leaner than stoich because of the wider flammability limits of diesel. So at normal cruise diesels use much less fuel than gasoline and are more thermodynamically efficient because of their higher compression ratio, which is how an 8,000lb diesel truck can get 20+ mpg all day long. When diesels run close to stoich they smoke like freight trains because the fuel takes much longer to burn.
Does that clear anything up or just make more questions?
Suppose I should have clarified... What most people use detonation as conversationally is intentionally igniting the mixture too soon. If preignition is leading to detonation all before the plug fires....you've done something horribly wrong You can have detonation without preignition, though. I'd wager its the most common source of knocking. Just add way too much timing and the spark will ignite it soon enough to detonate long before anything gets hot enough to cause preignition
Ops, I just realized that smokeshow took a shot at you even before I did, you didn't seem to care though.
Like I mentioned earlier, detonation is an event that happens after the plug has fired. It’s caused by too much heat and pressure inside the combustion chamber. The high heat and pressure become great enough to light off the remaining AFR mix all by itself. The result is multiple flame fronts inside the combustion chamber. When this occurs, you get a sharp spike in cylinder pressure. If you were data logging cylinder pressure you would see a steady rise in pressure as normal combustion occurs, followed by a sharp but brief spike caused by the detonation. The sound you hear, referred to as knock, is the engine itself and the rotating assembly absorbing the shock, not the actual combustion inside chamber. The frequency of detonation is close to 6400 Hz, in almost all engines – with little or no difference between aluminum and iron blocks. The knock sensor picks up vibrations at this frequency and tells the ECU to pull timing and / or add fuel. Severe detonation can’t be compensated for by the factory ECU, although there are some aftermarket systems that will go as far as to shut down the motor under severe knock. Moderate levels of knock will cause bearing wear, something often misdiagnosed as normal wear or some sort of lubrication issue. Bearing wear can turn into rod knock real quick. Lock up a bearing and you throw a rod through the block in most cases.
So, tell me again how can you not have detonation without pre-ignition, im still waiting for your counter argument buddy. You now have two options:
1- admit you were wrong and apologize to everyone for providing them with misleading information as "facts"
2- backup your statement, given that you will have to turn against your bestie smokeshow in the process.
Old Jul 20, 2014 | 05:17 PM
  #29
smokeshow's Avatar
You made a fool of yourself, bro. I got rid of your dumb *** because I get tired of explaining things to idiots who think they are right regardless of the information presented to them. You can lead an ignoramus to knowledge, but you can't make him think.
Furthermore, no ad hominem has occurred at all here. Might want to work on your knowledge of logical fallacies. Here's a quick lesson for you...this is called the genetic fallacy:
You are wrong and ******* retarded because you think magical evil genies possess your friends.
While that most certainly is a genetic fallacy, lets be real here: how in the **** is anybody supposed to take you seriously when you're so prone to believing things that would get you put in a psych ward? For anybody reading...yes indeed, that is what this clown believes.
I will have a discussion about the science behind engines, but I will NOT debate with someone who simply debates for sport.
Old Jul 20, 2014 | 06:05 PM
  #30
Atomic's Avatar
I do not care that much because that is a small detail. If that piece of semantics is all you took away from this thread then I really feel you missed the bigger picture. The physics of detonation and preignition are different. Can you have detonation without preignition, potential yes, so I was mistaken on that point. However, the chances of this actually happening are very small since most of the time, especially dealing with these engines detonation is caused by preignition. You can certainly have detonation even without spark plugs such as in a diesel!
Feel free to enlighten us with your vast knowledge on the subject.
Oh and that paragraph you quoted, I dont know who said that, but that are not totally correct. If we are randomly quoting segments of (mis)information from random sources on the internet now I see no reason for this thread to remain active.
