Qwank's 2017 Regular Cab Z71
Old Feb 27, 2019 | 11:33 PM
  #61
qwank's Avatar
Originally Posted by Mileguru
Thank you! The belt they sent me was a regular old Gates Century Series Micro-V K060938 6PK2385 (94.5 inches). Wow, your belt is MUCH shorter! So what gives? Why did Magnuson use a 94.5" belt for an 84mm pulley? And now they have me using it on a 78mm pulley. I'm going to call Gates tomorrow to figure out what size belt I should buy (something I shouldn't have to do or pay for).
Do you know what boost level you're getting yet?
I think your Maggie kit has the pulleys set up differently and it definitely looks like it uses a longer belt.
I was seeing 10psi on my boost gauge on the few WOT runs I did. I'm not sure why the SLP blowers are making more boost. maybe someone on here will now the answer.
Old Feb 28, 2019 | 08:49 AM
  #62
Mileguru's Avatar
Yeah, you're right. I hadn't looked that closely at you engine bay pic. I guess the pulleys and tensioners are in different locations for a 6.2 vs a 5.3 (I don't have a 5.3 to compare my 6.2 to).
Old Feb 28, 2019 | 09:00 AM
  #63
qwank's Avatar
the pulleys are all the same on the stock motors, it's just Magnuson and SLP set them up differently.
One last thing I did before I go in for my tune is change the orifice jet in the bypass valve from SLP's 0.017'' orifice, to a 0.030 orifice. This will allow the bypass valve to close a little bit quicker and build boost a little earlier.
Old Mar 1, 2019 | 10:15 AM
  #64
Vortec350ss's Avatar
How'd it do?
Old Mar 1, 2019 | 10:50 AM
  #65
gonzo 6.2's Avatar
Ditto,how did it do?
Old Mar 1, 2019 | 07:11 PM
  #66
qwank's Avatar
How'd it do?
We didn't get to finish the tune because for some reason the PCM is pulling fuel at 4,600 rpm so it was going lean. He said he thinks he figured it out though so I have to go back. I'm going to install a wide band gauge first though.
He did do some pulls up to 4,600 rpm and it did 404/503 and this was before pulling any timing , so there's some good potential there.
Old Mar 2, 2019 | 08:22 AM
  #67
Matt24's Avatar
What RPM does your boost come in now and anymore info on where to get the orifice and how to change it?
Old Mar 2, 2019 | 08:54 AM
  #68
qwank's Avatar
I haven't driven it really hard yet since the tune is still not complete.
but the orifices are just nitrous jets, so I went to my locals PepBoys and bought a new one. Looks like you have a Magnacharger, yours might already be a .035'' I probably wouldn't go any bigger.
Old Mar 27, 2019 | 06:26 PM
  #69
qwank's Avatar
My new gauge set up. Bank's scan gauge, GM Performance boost gauge, and AEM wideband.
Autometer 3 pillar pod painted Ford Dove gray, paint code 4N1
Old Mar 27, 2019 | 08:13 PM
  #70
Feed's Avatar
Well its no grab handle but it looks good
