New 5 in aluminum Driveshaft 2015
Old Oct 26, 2016 | 03:21 PM
Chalino Sanchez's Avatar
Default New 5 in aluminum Driveshaft 2015
Broke my oem driveshaft on a 60roll going130+mph. got eaton posi (nonG80) 3.73 gears forged axles n turbo ,single cab. Got a new one install by fb@got torque differentials in an Antonio tx . Runs smooth n its good for 180mph 5" shaft with 1410 joints and forged yolks.
Old Oct 26, 2016 | 03:34 PM
FFDP's Avatar
Ha, even the steel shafts have cardboard in them lol.
Old Oct 27, 2016 | 10:12 AM
Ryan Mills's Avatar
hmmm.... Interesting. I wonder if this would be an easy solution for us guys with the vibrating factory crap? What did that set you back?
Old Oct 27, 2016 | 05:27 PM
07Softail's Avatar
All they need to do is have the runout tolerance checked on the straightness of the driveshaft. That's what I did and it fixed the shake-vibration factory Bullshit!
RT
Old Oct 27, 2016 | 10:03 PM
I upgraded for rolls is mexico but stock or 2pc should be fine for normal use.
Old Oct 31, 2016 | 11:39 AM
Ryan Mills's Avatar
RT
So if runout is out of tolerance, it can be fixed? wht do they do, just rebalance the shaft? I have a one piece jobbie, since it's a RCSB
Old Nov 1, 2016 | 07:26 PM
07Softail's Avatar
If it's out of tolerance on how straight the shaft is it can be straightened. Mine was bent so to speak 1/16 of an inch and they straightened it they checked balance after it was straightened and balance was fine.
RT
Old Nov 5, 2016 | 11:41 AM
redrocker's Avatar
those speeds without a drive shaft loop? not very smart.
