Need help dead in the parking lot P0106 code
Old 03-27-2019, 01:44 PM
  #31
Jonblarc7's Avatar
No bang that i remember just pulled off the hwy like normal and it stumbled then started runing like the video above. I'm having it towed home right now. I googled how to read a miss fire with my VCM scanner so I'll hook that up and maybe try and get the drivers side valve cover off. It sounds like it's on the drivers side to me.
Old 03-27-2019, 02:07 PM
  #32
Jonblarc7's Avatar
Oh and oil is maybe 2 months old and looked fresh when I pulled the dip stick out in the parking lot.
Old 03-27-2019, 08:43 PM
  #33
Jonblarc7's Avatar
My three year old had his first ever T-ball practice. So there was no way I was going to miss that. Looks like cylinder 5 is missing the most.
Here is a screenshot for those that can't open VCM.
Old 03-27-2019, 08:44 PM
  #34
Jonblarc7's Avatar
and the VCM file
File Type: hpl
Old 03-28-2019, 05:56 AM
  #35
Mod with training wheels
smokeshow's Avatar
Something definitely looks dicked up with those sensor values. You need to get a multimeter on the 5V rails and see if one isn't shorted to 12V or something.
Old 03-28-2019, 07:36 AM
  #36
Jonblarc7's Avatar
Sorry this is where I'm a complete newb. What do you mean 5V rails?
Old 03-28-2019, 10:22 AM
  #37
00pooterSS's Avatar
You can hear it in the video you posted.
You're wasting time looking at data.
You need to get into the engine. Do a compression test and or pull the valve covers and start there. A misfire won't make it violently shake like that, you have a major issue. I bet you have a valve dropped and it's pushing compression up the intake and causing all other cylinders to go crazy and the MAP sensor. Not trying to be a dick, I've been a tech for 20 years and seen situations like yours several times. Had a ford in a couple months ago that dropped a valve and knocked a big *** hole in the piston and it was acting very similar to yours, except it actually ran better than yours.
Old 03-28-2019, 10:24 AM
  #38
00pooterSS's Avatar
Here it is after I put the first map sensor. It changed nothing.
https://youtu.be/dL5xK7Scp_0
18 seconds in on this video BANGING NOISES
Here is the video with the correct map sensor. I don’t think a sensor would make it do this
https://youtu.be/UoBxukBiGaI
3 seconds into this video loud BANG
Again, you don't have a sensor issue, you have an engine issue.
Old 03-28-2019, 11:33 AM
  #39
Jonblarc7's Avatar
Don’t think your being a dick at all. I wanted your opinion spacifiy.
Wife and kid leave for the lake this afternoon. So as soon as I get home I’m pulling the valve covers
Old 03-28-2019, 12:53 PM
  #40
00pooterSS's Avatar
Okay cool man.
I would help more with the graphs you posted but the graphs and info you are using are very different than what I use. I use snap on, matco and tech 2 scanners and it comes up differently.
Quick Reply: Need help dead in the parking lot P0106 code
