Need help dead in the parking lot P0106 code
#31
No bang that i remember just pulled off the hwy like normal and it stumbled then started runing like the video above. I'm having it towed home right now. I googled how to read a miss fire with my VCM scanner so I'll hook that up and maybe try and get the drivers side valve cover off. It sounds like it's on the drivers side to me.
#32
Oh and oil is maybe 2 months old and looked fresh when I pulled the dip stick out in the parking lot.
#33
My three year old had his first ever T-ball practice. So there was no way I was going to miss that. Looks like cylinder 5 is missing the most.
Here is a screenshot for those that can't open VCM.
#34
and the VCM file
#36
Sorry this is where I'm a complete newb. What do you mean 5V rails?
#37
You're wasting time looking at data.
You need to get into the engine. Do a compression test and or pull the valve covers and start there. A misfire won't make it violently shake like that, you have a major issue. I bet you have a valve dropped and it's pushing compression up the intake and causing all other cylinders to go crazy and the MAP sensor. Not trying to be a dick, I've been a tech for 20 years and seen situations like yours several times. Had a ford in a couple months ago that dropped a valve and knocked a big *** hole in the piston and it was acting very similar to yours, except it actually ran better than yours.
#38
18 seconds in on this video BANGING NOISES
Here is the video with the correct map sensor. I don’t think a sensor would make it do this
https://youtu.be/UoBxukBiGaI
Again, you don't have a sensor issue, you have an engine issue.
#39
Don’t think your being a dick at all. I wanted your opinion spacifiy.
Wife and kid leave for the lake this afternoon. So as soon as I get home I’m pulling the valve covers
