Mirror Moving On Its Own
Old 03-17-2015, 08:16 PM
MetallicaMatt's Avatar
Originally Posted by AKlowriderZ71
Yes, and every time you unlock the doors with your remote, the mirrors will move to the positions set for that fob. Which may be different from your other fob, and different from the buttons on your door panel switch.
Correct, but that is not the issue. I'm the only driver, my truck, my single key fob.
The second fob is locked in a safe.
Old 03-17-2015, 08:23 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
14 years of working at GM dealerships, every single complaint like this that I saw, was programming. Probably saw a dozen of these every week. Just trying to help you out.
Old 03-18-2015, 07:16 AM
No I understand and appreciate the feedback. I'm just more observant (okay, OCD) about things and tend to notice little things better than most people
So this morning, I back out of my garage, mirror doesn't move, passenger mirror adjusts down as it should. Put the truck in Drive. Passenger mirror goes back up as it should, driver stays. Start down my driveway (long drive) and I see my drivers side mirror moving down to face the ground. Ugh.
It was moving in a motorized fashion, not like the gears are stripped or anything.
Old 03-18-2015, 11:31 AM
Lunch time:
Remote start truck, leave work, no issues. Reverse into the spot at my destination, move back to drive and the mirror moved.
Leaving lunch, starting truck with the key, could not duplicate. I'll have to try remote starting and doing that process again to see if it repeats.
Old 03-19-2015, 11:22 PM
RacinRust's Avatar
See Vehicle Personalization on page 5-47 in you owners manual before you visit your dealer. Thats where I'd start.http://www.chevrolet.com/content/dam...nersManual.pdf
Old 03-20-2015, 07:12 AM
I'm assuming you're referencing the Reverse Tilt Mirror option? Which I stated in the OP that it is turned ON for the Passenger side only.
Old 03-20-2015, 10:58 AM
RacinRust's Avatar
Just trying to help. Sometimes these things have to be disabled then re-enabled to learn correctly.
Old 03-20-2015, 01:44 PM
Jordan927's Avatar
+1
Reset to factory settings and see if it happens using the method you have found it to consistently occur. If it does not move on its own then, set everything back up the way you like it and try it all out again.
Signal voltages are funny sometimes. Stray voltages can signal your electronics to do all kinds of things its not supposed to.
Old 03-20-2015, 01:46 PM
Oddly enough, I have not been able to reproduce it today.
The other day, I could reproduce the condition all day long, as long as I followed the right sequence of steps.
My only thought is that over the weekend we had rain and then took it to the car wash. Perhaps there was a short and now it dried?
Who knows. I'll keep an eye on it and make the dealership aware of it. Certainly an odd bug.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
03sierraslt
14
10-09-2015 05:53 AM
Wrecker 426
10-07-2015 12:11 PM
Slammed silverado
09-28-2015 06:14 PM
vmaxpro
09-28-2015 11:10 AM
Quick Reply: Mirror Moving On Its Own
