LT engine rocker arm setup
Old Dec 11, 2017 | 01:33 PM
91LT16SpeedFormula's Avatar
Default LT engine rocker arm setup
Are they different then the LS style?
Old Dec 11, 2017 | 01:50 PM
Nvm figured my own question out already lol
Old Dec 11, 2017 | 05:18 PM
Slapps74's Avatar
And the answer was?
Old Dec 12, 2017 | 08:00 AM
The new LT based rockers are 1.81:1 now more like the LS7 rockers were. The valve angles are different also and place the rockers in a different mounting position compared to the LS based engines. I had a set of Jesel's that I wanted to swap over to an LT but they will not work and so far noone has a rocker setup that I saw for the LT engines. The best upgrade so far Ive seen is just to do the trunnion swap
Old Dec 12, 2017 | 10:07 AM
Slapps74's Avatar
I have seen Texas Speed has a trunnion kit that uses bushings instead of the captured needle bearings like the comp cams kit does. Not sure which one would be better.
Old Dec 12, 2017 | 10:12 AM
thewrx's Avatar
whats the valve angle? Curious
Ive used the Comp kit and never had a problem but some have said they've had the Comp trunnions come apart on them. To me I think thats valvetrain issue but Im no professional. At least w/ the bronze bushing setup there is no parts to be pushed thru engine if something happened
Old Dec 12, 2017 | 10:31 AM
Sorry this was on the LT1,not sure if all the LT engines are the same
Intake valves are 12.5-degree angle from vertical & 12 degrees on the exhaust
Attached Thumbnails LT engine rocker arm setup-gm-gen-v-lt1-engine-gen-v-vs-gen-iv-valves-top.jpg
Old Dec 14, 2017 | 08:23 AM
Slapps74's Avatar
I just picked up my stuff fro TSP and the recommend the bushings. They look like very nice stuff.
Old Dec 18, 2017 | 07:46 PM
FELONIOUS1's Avatar
I believe Jesel introduced some at the PRI show last week
