HID's & drl's?
Old Sep 26, 2014 | 11:02 PM
5speedsilverado's Avatar
Default HID's & drl's?
anyone figure out how to get HID's to work with the DRLS? when the DRLS are on the hid's just flicker. all i have is the relay harness and the HID kit.
Old Sep 26, 2014 | 11:12 PM
FFDP's Avatar
I don't know how things work with the new trucks but aftermarket HID's and DRL's are always a no go in my eyes and experience.
DRL's don't provide full voltage to the bulbs and thats why they flicker and soon the ballasts will die because they need to see more power, the bulbs can suffer aswell.
Old Sep 27, 2014 | 09:49 AM
Three6GMC's Avatar
If you have the relay for the hids then use the drls power wire as a signal to your relay (85) and you will be fine. Your relay will give them full voltage and amps. If its still flickering with the relay then you have a problem with your ballast or bulbs... I like to run hid kits from the retrofit source as they have a real wide voltage range 8-32v, I run these straight connected to my factory harness no relay or extra stuff and have had them work just fine for years now.
Old Oct 2, 2014 | 10:15 PM
i forgot about this. i have a relay harness, and when the drl's are on the relay clatters like its opening and closing really fast. apparently GM uses pulse with modulating to dim the head lights for drls. idk how to make this work.
Old Oct 3, 2014 | 05:47 AM
1lowgmc's Avatar
Dump the HID and go LED. Just as bright if not brighter and way less pain in the ...
Old Oct 3, 2014 | 10:26 AM
KozzyJr's Avatar
Just 3 times the price
Old Oct 3, 2014 | 02:00 PM
1lowgmc's Avatar
$70-$100 on amazon?
Old Oct 20, 2014 | 07:50 PM
SolomonAKOO's Avatar
check out intensehid.com and then get the flicker relay. Thats what i did and i havent had any problems.
Texas5.3_1251
Mar 5, 2016 08:10 PM
the owl
Sep 4, 2015 04:09 PM
BIGD4504
Aug 19, 2015 07:57 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Ammadien
Jul 22, 2015 08:50 PM
