Drag Radial set up Help
Old Jun 7, 2016 | 01:53 PM
Evan Savon Spears's Avatar
Default Drag Radial set up Help
so I'm stepping into new territory, trucks and drag set ups. I have a 2016 Silverado 1500 WT 5.3L L82 with a 3.08 rear axle.
I originally wanted to widen my rear rims from 17x8 to 17x10 and throw on some Mickey Thompson ET Streets S/S 275/40R17 but I figured that might be dangerous to run custom widened steelies.
So I was thinking I might be able to get away with some Pro Comp 51 series 15x10 on the rear, and keep the front the stock 17's.
The question I have is will the 15x10 fit the rear and if so what size tire should I get for the PC51's. (BTW the rear is going to be dropped an inch from removing the stock lift block).
Old Jun 7, 2016 | 07:02 PM
fabiangmc's Avatar
No. 15" wheels will not clear stock brakes.
Old Jun 7, 2016 | 07:24 PM
yeah I should have guessed that. will 16" work or am I stuck with 17"?
Old Jun 13, 2016 | 05:33 AM
formula53's Avatar
Not sure if they changed anything on the 16's but on my 15 wt 17's is as small as you can go.
Old Jun 13, 2016 | 07:21 AM
fabiangmc's Avatar
Yeah I believe 17" is smallest you can go on stock. You can buy brackets to do a brake conversion to fit 15" in the rear.
Old Jun 13, 2016 | 11:05 AM
RS/SS 4.8's Avatar
10 Second Truck Club
If the wheel widening is done right there should be no problem with the wheel. Also racestar sells direct fit 17x9.5 for these trucks.
Thoagland
70
Sep 1, 2016 04:25 PM
ClintBeastwood
Mar 21, 2016 11:52 PM
MOBBN
Mar 13, 2016 08:59 AM
YAMAHAGUY
Mar 12, 2016 07:17 PM
nitrousaddict
Mar 12, 2016 03:47 PM
