Double Adjustable Shocks
Old 11-04-2016, 05:56 PM
ZO6Ted's Avatar
Yeah I know that would do a great job but Atomic said shocks would probably do it as well. Then there is the f'ing with it every time I go to the track. I was just thinking since the factory struts are weak suck anyway it would be great when loaded on the street instead of seeing air under the front tires every time I see a healthy bump and with a track setting give me some good 60's. Would love to see 7's as it sits. I appreciate the replys and pms!
Old 12-16-2016, 04:19 PM
BIGRED811's Avatar
I would recommend going to a coilover- But you don't have to go though all the hassle of figuring out shock length, spring rate mounting etc.
Many companies make bolt in replacements for these platform trucks. Just bolt in and align the truck. Adjustable from 1" of lift to 3"
I would recomend Icon Vehicle Dynamics, King or Fox.
I can provide any info needed if you're interested in this route !
Old 04-28-2017, 10:40 AM
ZO6Ted's Avatar
Been riding around for a few months on Rancho 9000 struts and just did the rears yesterday. Went for a spin and checked out the launch loaded of course because I'm in AC season now. My 1st impression is it doesn't squat anymore in the rear. Just chirps the front tires pretty good and goes leaving at idle and that's at street pressure on the tires of 34lbs. Before it would buck pretty bad and lose traction. Settings are at #9 front and rear because of my weight loaded. Sure does ride and handle well and controlled now. The fronts made the most difference though. It will be after Summer before I can get it unloaded for the track. Not double adjustable but they sure did help and price wasn't too bad either.
Old 03-21-2020, 07:27 PM
ZO6Ted's Avatar
Same question. Is there anything double adj out there yet for the front? I just hate to do limiting straps. Atomic? Do you make a conversion?
Old 03-23-2020, 04:39 PM
00pooterSS's Avatar
I wouldn't pulley up until I put exhaust on it
I bet you'll gain more putting exhaust on it than you do from the pulley. You're shoving a lot of air into a clogged up straw right now. And your truck falls off on the top end pretty bad. Exhaust should help quite a bit. SE headers and their true dual kit. It'll be a bit loud but you can add mufflers or something later if it's too loud for your old ***.
Jonblarc7 (03-23-2020)
Old 03-24-2020, 04:22 PM
ZO6Ted's Avatar
Good point. I think I will when I get the turbo setup going on the other one. It has a 14" Magnaflow on it and it sounds great and isn't loud so I guess duals would be good. I will likely do it all at once though. Exhaust, fuel, E85, and pulley, retune. Haven't decided if cam yet though because I'm going crazy on the other one.
Old 03-24-2020, 05:16 PM
00pooterSS's Avatar
If nothing else swap the cat back from the blue one over to the red one then put your dual setup on the red one.
walledition
11-13-2015 05:29 PM
sTNT971
01-09-2015 05:26 AM
Suburbazine
11-19-2014 07:06 AM
fastrt
08-31-2010 02:00 AM
Sport Side
11-13-2004 12:36 PM
Quick Reply: Double Adjustable Shocks
