better lowering struts?
Old Jul 15, 2017 | 09:11 AM
Ryan Mills's Avatar
Default better lowering struts?
Hey guys, I was just wondering if you know of any better lowering struts than the McGaughy's that I'm currently running. I think I have them about 1" lower than stock, but they are way too soft in my opinion. If I hit a dip after a bridge on the highway, the front end bounces 2-2 1/2 times before settling out. So, Anything adjustable out there? coilovers maybe? Thanks!!!
Old Jul 15, 2017 | 10:47 AM
ToNasty's Avatar
The belltech are a little stiffer but I think they're all pretty much the same
Old Jul 15, 2017 | 06:25 PM
Feed's Avatar
I have run belltechs on a regular cab and crew cab. I like them. They weren't bouncy.
Old Jul 15, 2017 | 09:54 PM
Atomic Performance's Avatar
Former Vendor
I make a coilover bracket kit for these trucks and am a dealer for Viking to get you set up with everything you need for coilovers so you can tune the ride however you want
https://atomicfabandperformance.com/...over-brackets/
Old Jul 16, 2017 | 11:27 AM
ToNasty's Avatar
This is what he been wanting to do but I can't figure out the length and spring rate for the coilover
Old Jul 16, 2017 | 05:46 PM
Former Vendor
I can do all of that for you, I just need you to measure from the center of the wheel straight up to the fender as it sits right now and let me know how much drop you want
Old Jul 16, 2017 | 07:41 PM
ToNasty's Avatar
I m already lowering struts and spindles but I want to ditch the struts for more adjustability
Old Jul 16, 2017 | 10:51 PM
Former Vendor
Sure thing, I just need you to measure how your truck sits right now. Ideally from the top of the spring shock perch on the frame to where the strut mounts on the LCA at the ride height you want. The other way is to measure from the center of the wheel straight up to the fender and tell me that and what lowering components you currently have.
I can get you set up with what you need, but I need to know one of those things to get you the right shock and spring.
Old Jul 17, 2017 | 12:21 AM
ToNasty's Avatar
Awesome. When I get the truck back I'll send you measurements
Old Jul 17, 2017 | 09:26 AM
Ryan Mills's Avatar
This is an interesting option! with the coilover brackets, is there any additional vibration or noise? Also, it does state that they're for the GMT900, but I'm assuming they will work on the newer model as well, correct?
When looking at the brackets, are the coilovers that show up under "bought together" or whatever the coilover that you would suggest?
I have no idea what spring rate I would need either.. I'm really interested, just need help!
