2014 sierra tru cool
Is this under the block? Built in to the block? I thought it was weird the temps pretty much stay at 190 after TC and additional cooler install. With both the stock cooler and the 40k inline it should be much cooler this my explain why I have t seen much change... anybody get around to doing a write up?
just follow the t-stat to where the trans cooler lines go into the transmission.
Both transmission lines go into the t-stat. The t-stat is bolted to the trans.
190 is not overheating, our fluid is a little better these day.
Unless you're racing I don't see the point other than justifying your trans cooler purchase which you likely wasted your money on
the tstat should be under driver side , do not let run too cold or it will ruin transmission .
mrobvious34
Feb 29, 2016 08:55 PM
Turbo Silverado
Feb 24, 2016 05:28 AM
