need pics of DJM 2 and 4 inch drop LCAs
i ordered a djm 4/6 drop but once on the ground the front of the truck is sitting 2 inches higher than the back. im thinking that maybe i was sent 2 in drop LCA rather than 4in drop LCAs. But i need pictures of each to see which ones i have. after back together the front of my truck only sits 2 in lower than before, but the back is right at 6 in. Also when you install DJMs LCA d you re-use the rubber spring isolators or remove them?
thanks
thanks
My truck has djm 4/6 kit on it (I've lowered it more since then) but when it was just the 4/6 kit it sat fairly level, maybe a touch of rake towards the back. I also left the rubber bushings in it. I can't provide pictures of my 4" arms at the moment
