2014 Catch Can install
Old Jan 11, 2015 | 06:40 PM
03sierraslt's Avatar
Default 2014 Catch Can install
Decided to install a catch can asap to help with any carbon build up on intake valves. Its a Mike Norris catch can. Once I pulled the intake tube and throttlebody I wiped out the intake, I basically had nothing in the intake but my truck only has 4k on it so I didn't expect anything crazy. Mine is a 5.3 so the crankcase vac. tube runs from under the TB to the drivers side of the intake manifold about half way back.
Nipple below where the TB mounts.
Attachment point on intake manifold.
With the New lines attached.
I attached the catch can bracket to the brake master cyl. mount bolt.
The Top line on the catch can runs to the port below the TB, the bottom line on the catch can runs to the intake manifold.
Guess we will see how much I get in it.
Old Jan 11, 2015 | 06:42 PM
BlackGMC's Avatar
Resident Retard
Nice. Tbose new motors look alot different than the older ones.
Old Jan 11, 2015 | 06:47 PM
Ya, there is basically nothing that is the same.
Old Jan 11, 2015 | 08:04 PM
PSM's Avatar
PSM
Any plans for the clean side?
Old Jan 11, 2015 | 08:06 PM
Vortec350ss's Avatar
Very interesting that the crankcase vent is there as opposed to the valve cover. I wonder if that new location is better for oil consumption to begin with.
I have seen a lot of DI carbon build up pics... but I haven't seen much specific to the GM DI engines yet. I'm sure its out there, I just haven't come across much.
Old Jan 11, 2015 | 08:11 PM
No, I don't really see the point. It draws fresh air from the intake tube into the valve covers. The valley cover has a vac. On it via the intake so air should always be drawn in one direction. If I start seeing any carbon build up on TB then I'll revisit the idea.
Old Jan 11, 2015 | 08:17 PM
PSM's Avatar
PSM
I suppose you only lose that vacuum during excessive WOT or if you have a Trubo or centri.
Old Jan 11, 2015 | 08:24 PM
With boost you would need a check valve but I have no boost planned in this trucks future. When the warranty is up ill tune it and at most ( I say this now) a mild cam.
Old Jan 11, 2015 | 08:26 PM
PSM's Avatar
PSM
Famous words
Old Jan 11, 2015 | 08:32 PM
Famous words
Yes, very true. It will at least be stock till warranty is up. It's my DD and has a car seat...... I have other toys besides the truck so I need to leave it.
