2014 5.3 cam swap and dod delete?
Old Jan 8, 2015 | 09:57 AM
meadows's Avatar
you need the katech valley cover and non-DOD lifters. then whatever cam you want installed, with DOD disabled in the tune.
Old Jan 15, 2015 | 05:51 PM
Vortec350ss's Avatar
I'd like to see more data on the fuel pump lobes. How aggressive they can be. Is that the only difference between these engines and say whats in the LT4? The LT4 runs nearly 2900 PSI while the regular motors are running closer to 2100. That said... can the standard fuel system withstand that pressure increase?
Old Jan 15, 2015 | 09:39 PM
thewrx's Avatar
They only go up to 30% right now but honestly you got some room to play as they are 120lb injectors and you could swap injectors with 6.2 or just run meth and be good up to 600 hp.
Old Jan 17, 2015 | 07:22 PM
meadows's Avatar
this is incorrect. go to comps website. many different lobes.
MattOKC
Aug 18, 2015 11:30 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
EscaTruck
Jul 20, 2015 11:42 AM
06 4.8
Jul 15, 2015 07:17 PM
Aboss
Jul 9, 2015 10:28 AM
