2/4 drop, pinion angle question
Old Feb 25, 2016 | 06:46 PM
steves86ta's Avatar
Default 2/4 drop, pinion angle question
HI All,
When new, my truck had a slight vibration from the drive line. I took it to the dealer and they put 2 degree wedges in. It took care of the vibration and was fine for about 35k miles.
Around christmas time i bought myself a 2/4 drop kit. After installing it, the vibration came back much more violently than before. Being down this road once, and knowing i just lowered the truck thus changing the pinion angle. I bought a set of 6 degee wedges.
They helped tremendously. But theres still a vibration, especially when towing/accelerating. Its not as violent as before, but still there and id like to get rid of it.
My question to you is, if you lowered your truck what degree wedge are you running? Also... Does anyone know of a transmission mount spacer maybe a half inch or so?
The boat is also powered by a HCI 5.3 with some giggle juice
Old Feb 25, 2016 | 07:53 PM
FFDP's Avatar
You are going to have to measure the angle see and what it's like. There is kinda only a gray line here with what it may need shim wise, some trucks are different than other.
Old Feb 26, 2016 | 07:35 AM
bigsapper's Avatar
Belltech has a trans spacer. Contact Suspension Source.
Old Feb 26, 2016 | 09:21 AM
97low's Avatar
I have a 2/4 drop on my 08 CCSB I used a 1/2 spacer under the trans and I cant remember the degree of the wedges. I don't have any vibration until I get up to about 100MPH and I think that is due to the tires I'm running.
Old Feb 26, 2016 | 10:25 AM
steves86ta's Avatar
Thank you!
Old Feb 26, 2016 | 10:26 AM
steves86ta's Avatar
Thank you for the info
Old Feb 26, 2016 | 10:27 AM
steves86ta's Avatar
Yea, i was just looking for information.
I need to pull the wheels and check the brakes this weekend. So ill crawl under and measure it
Old Mar 30, 2016 | 07:59 PM
RedLS's Avatar
That's not your tires. Sounds like your drive shaft is about to explode. 100mph is the critical speed of these driveshafts. Ide take it easy. lol Tire vibrations will come at around 65-75 mph give or take a few.
stealthperf
Feb 10, 2017 01:08 AM
LJ93Z28GM
Feb 1, 2016 03:14 PM
Slow53
Jan 7, 2016 08:34 PM
stealthperf
Jan 6, 2016 11:03 PM
Shack
Dec 31, 2015 01:22 PM
