2/4 drop 4wd RCSB Shock Recommendation
Old Jan 5, 2016 | 09:12 PM
LJ93Z28GM's Avatar
Default 2/4 drop 4wd RCSB Shock Recommendation
Been a long time since I have been on this site since I sold off my old truck.
Snagged a RCSB 06 Sierra 4wd. Previous owner did a TB crank, but I will be going in the opposite direction and doing a 2/4 drop.
Currently it sits 4" taller than my fathers RCSB 2wd NBS.
Just looking to get it close to a 2wd stance leveled out.
Going to decrank the TB, remove block and shackles. Mod the bumpstops correctly and see how it rides. Currently the ride is not that great since it is off the bumpstops up front by 3/4"
Question is am I in need of new shocks after the 2/4 drop front and rear? I would like to get by on the stocks for a bit to see if I like the ride. If the ride sucks I will do the coilover conversion from atomic. This is a weekend fun truck, so if it is a decent ride I will live with it versus dropping $700-800 for the conversion.
Old Jan 5, 2016 | 09:28 PM
FFDP's Avatar
You will want drop shocks in the rear for sure.
And you'll only get 3in if you remove the block and go to drop shackles. You might see 3.5 if you remove the overload spring.
Do some drop spindles up front.
Old Jan 6, 2016 | 10:35 PM
TrevorH's Avatar
Similar thread on shocks: https://www.performancetrucks.net/fo...lstein-538622/
Old Jan 9, 2016 | 10:15 PM
LJ93Z28GM's Avatar
Trevor thanks for the thread link.
As for the drop spindles it would be coil overs for the cost difference.
I worked on the truck a bit today and took out the rear block and dropped the front down so it rides leveled.
Weather was crap today with snow, so I did not bother to see how the truck rides now since it would just slide around.
I will order up some shocks and drop shackles and see how more I can get out of the stock keys and alter the front bump stops accordingly.
If it rides like crap, then coilovers.
Old Jan 10, 2016 | 06:02 AM
MidnightExpress99's Avatar
Mine were blown when I bought my truck. I ran KYB monomax, rides a little more firm but responsive. Also ran the McGaughy's rear shock extensions and it was night and day better.
Old Feb 1, 2016 | 03:14 PM
Atomic's Avatar
I have a gauge for that
Let me know if you want to get rid of those pesky torsion bars
matemike
Dec 29, 2015 08:12 AM
Jlipton72
Dec 21, 2015 09:05 AM
CAlegre
Dec 9, 2015 10:48 AM
walledition
Dec 7, 2015 09:55 PM
