Who has swap the driveshaft of the cc to the one of a nbs extended cab?
Old Jun 29, 2012 | 08:28 PM
LaBlackIce's Avatar
Default Who has swap the driveshaft of the cc to the one of a nbs extended cab?
Some people told me that you can swap the stock driveshaft of a nnbs crewcab to the older style 05 extended cab two piece steel driveshaft has anyone done it?
Old Jun 29, 2012 | 09:49 PM
iamkeniff's Avatar
I have. Make your crossmember an put a conversion u-joint unless you find a SS dshaft that already comes with 1350 u-joints
Old Jun 29, 2012 | 09:55 PM
LaBlackIce's Avatar
So i have to change the u joints right?.. and also do you have any vibrations or any type of problems with the two piece? Is can i want to lower more my truck and with the performance mods i dont want to break the stock while im going fast..
Old Jun 30, 2012 | 09:38 PM
iamkeniff's Avatar
99-04(or 05) is a 3r u-joint and the newer truck 07+ is a 1350. You need 1 3r to 1350 u-joint for the rear shaft to rear end or find a dmax 2 peice or a SS 2 peice. You can have someone build you a 3-3.5" one that way its all one size u-joint.
No issues with a bone stock 00 2 peice in my cc. It went 130 an was smooth, after my mcg flip kit i started getting a vibration bc the pinion angle is off 4*
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
1bad2k
Aug 18, 2015 09:50 PM
OLD BULL
Aug 1, 2015 05:00 PM
kkirwan71
Jul 28, 2015 06:39 PM
Jake75
Jul 22, 2015 09:20 PM
