Tired of the "MONSTER TRUCK" look!!
Old Aug 19, 2009 | 04:38 PM
2HighN2FlyZ71's Avatar
Default Tired of the "MONSTER TRUCK" look!!
Not really wantin a "SLAM" just want like a 2/4 drop!! what would be the best way to go!? i only have one concern i WANT IT TO SIT LEVEL!
Old Aug 19, 2009 | 04:51 PM
CI DENALI's Avatar
The easiest and cheapest way is probably to use 2" drop spindles in the front and 2" drop shackles in the rear and take out the 1 1/2" spacer block under the leaf spring. That way you should get a 2/3.5" drop.
That's what I'm gonna do, and I'm with you on the lower and level look without scraping the ground.
I have already installed the 2" drop shackles and the truck is now just about perfectly level so a further 2" in front and 1 1/2" in the back ought to look real nice, without breaking the bank, to boot! I would've attached a pic but the ones I have are apparently too large to download?!
Old Aug 19, 2009 | 04:55 PM
RandomHero's Avatar
Flip kit and a lift shackle for the rear if you ask me. That will put it at about 4-4.5 in the rear which would make it sit much more level.
Old Aug 19, 2009 | 04:56 PM
i have a 3'' shackle drop now and the block took out and it still sits up in the rear!!! ?????????
Old Aug 19, 2009 | 05:02 PM
RandomHero's Avatar
Read my post above yours again please
Old Aug 19, 2009 | 05:32 PM
so if i do the flip kit it and lift shackels it should sit about level?? and where could i get a kit like this from!! thanks again
Old Aug 19, 2009 | 06:22 PM
Occupational_Hazard's Avatar
I would have just bought 4" drop leafs.
Old Aug 19, 2009 | 06:24 PM
RandomHero's Avatar
Well the best way is to measure what it's currently sitting at and see how much lower you need to go in the rear to make it sit level. A flip kit with a lift shackle usually brings it to around 4.5" which makes it sit pretty darn close to level. If that's not low enough just put it on the second shackle eye and it will sit an inch lower.
Old Aug 19, 2009 | 06:39 PM
i only tow about 1500-2000 lbs so im liking the idea of the flip kit but would i NEED helper bags??
Old Aug 19, 2009 | 07:05 PM
lowoh8's Avatar
get air shocks
monroe ma743 i just installed some about 30 minutes ago on my 08, rides nice
i sit level with a 2" shackle and the block removed.
