Throttle Body Spacers???
Old Dec 1, 2008 | 02:18 PM
VMax's Avatar
Default Throttle Body Spacers???
do throttle body spacers make that much of a difference? and does it create like a high rise intake effect for your motor, since it is between the throttle and your intake??
Old Dec 1, 2008 | 02:23 PM
BLUES MAN's Avatar
The House is Rockin'
here check this sticky out.
https://www.performancetrucks.net/fo...d.php?t=395748
ChevyTruck's Avatar
something else
From what I have learned it does really nothing, just makes a wisle noise. I have one on my truck, it was givin to me so what the heck, I would not buy one. IMO
Old Dec 1, 2008 | 02:33 PM
BLUES MAN's Avatar
im sorry heres the full thread go down to post #8
https://www.performancetrucks.net/fo...06+GM+fullsize
Old Dec 1, 2008 | 03:54 PM
Mangled03gmc's Avatar
Baltimore Whore
NO it is worthless, save your money... Unless you want to plumb it for nitrous
John
Old Dec 1, 2008 | 04:05 PM
Wilde Racing's Avatar
How do I change this text
So sad to see so much mis information on here.......
Old Dec 1, 2008 | 04:12 PM
TB spacers...
These are probably the most misunderstood things there are. It seems that almost everyone installs one on his or her engine. Most people know that it helps top-end power, but they don't really know why. The answer is, it increases plenum volume, which reduces the induction pulses at the carburetor and brings the peak velocity through the Throttle body down. Most manifolds are made with plenums that are too small, so adding a spacer will usually help. Manifold companies know that the plenums are too small, but it is easier to add a spacer if it's too small, than to remove space if it's too big. Just about every engine design will be offered at different displacements. So a company must design a plenum to work well with the smallest displacement engine available or make sure that is marketed toward larger displacement or higher revving engines.
A better question would be, "Is my intake sized properly, or do I need a bigger plenum?"
Old Dec 1, 2008 | 04:17 PM
Baltimore Whore
Originally Posted by Wilde Racing
TB spacers...
So you are saying that putting a spacer between the tb on our trucks will actually make a difference and will get a power increase.. Pr are you refering to old school carbed style manifolds??
John
Old Dec 1, 2008 | 04:30 PM
00ChevyScott's Avatar
Wearin' da big hat
John
ya, that post confused the **** out of me.
Old Dec 1, 2008 | 04:34 PM
John
The theory is the same, though it was designed around a carb style intake. Much of the engine characteristics are dictated by the intake. Look at a ls1 or a fast intake. They change the power curve by flow? The biggest restrictors in most intakes are the valves… So how do the intakes flow more air? Helmholtz theory. By changing the length, taper, size of the runners and plenum you can “tune” the intake to perform in a certain rpm range.
Every time the intake valve closes it generates a wave. Helmholtz theory is basically trying to tune that wave to bounce of the intake and return to the valve just as it opens. Thus more pressure, better cylinder filling at that particular rpm range.
I have done just a touch of research on this topic for a project of mine. But There is much much more to this…….
