Throttle Body Spacers???
do throttle body spacers make that much of a difference? and does it create like a high rise intake effect for your motor, since it is between the throttle and your intake??
im sorry heres the full thread go down to post #8
https://www.performancetrucks.net/fo...06+GM+fullsize
How do I change this text
TB spacers...
These are probably the most misunderstood things there are. It seems that almost everyone installs one on his or her engine. Most people know that it helps top-end power, but they don't really know why. The answer is, it increases plenum volume, which reduces the induction pulses at the carburetor and brings the peak velocity through the Throttle body down. Most manifolds are made with plenums that are too small, so adding a spacer will usually help. Manifold companies know that the plenums are too small, but it is easier to add a spacer if it's too small, than to remove space if it's too big. Just about every engine design will be offered at different displacements. So a company must design a plenum to work well with the smallest displacement engine available or make sure that is marketed toward larger displacement or higher revving engines.
A better question would be, "Is my intake sized properly, or do I need a bigger plenum?"
TB spacers...
John
Every time the intake valve closes it generates a wave. Helmholtz theory is basically trying to tune that wave to bounce of the intake and return to the valve just as it opens. Thus more pressure, better cylinder filling at that particular rpm range.
I have done just a touch of research on this topic for a project of mine. But There is much much more to this…….
