Is there an unused switched fuse socket?
Old Jul 10, 2011 | 01:54 PM
Gh0st's Avatar
Jedi Master
Default Is there an unused switched fuse socket?
Going to wire up my wideband tomorrow and I'd rather not piggyback off of an existing fuse. Does anyone know if any of the unused fuse sockets on the GMT 900 trucks is a switched fuse socket that I can use solely for my wideband?
Old Aug 6, 2011 | 09:07 AM
Gh0st's Avatar
Jedi Master
Anyone?
Old Aug 6, 2011 | 11:32 AM
Dusty05's Avatar
I installed my remote amp wire and my gauges to a box under the dash! It's located under the dash, behind the emergency brake. It's the only "key on wire" that I found. I believe that box is to wire in the brake controller??? So far it has worked great!
Old Aug 6, 2011 | 12:12 PM
javzh's Avatar
The brake controller behind the e-brake has a swithed prong. I used an in-line fuse and connected it that prong. I forget witch one it is but you can test and check to find out.
Old Aug 6, 2011 | 12:23 PM
Gh0st's Avatar
Jedi Master
Cool, I'll check it out. Thanks.
Old Aug 6, 2011 | 01:15 PM
Foxxer's Avatar
Mine is connected with the key switch, added a fuse just in-case. Turns to be running great! Can't bother to toggle with NNBS fusebox, trucks are so computerized for me lmao.
Old Aug 19, 2011 | 12:41 PM
Gh0st's Avatar
Jedi Master
Do any of you mind taking a picture or telling me which prongs to use? I really don't want to go out and buy a multimeter.
Old Aug 19, 2011 | 04:07 PM
javzh's Avatar
If you haven't yet found witch prong. Here is a pic of mine. It's the bottom left prong.
Old Aug 19, 2011 | 06:19 PM
Gh0st's Avatar
Jedi Master
Thank YOU!
dantheman1540
Feb 24, 2016 09:56 PM
00loudchevy
Dec 3, 2015 05:54 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
