???s bout possible ECM swap
Old May 7, 2013 | 09:55 PM
BIGDADDY1969's Avatar
Cool
Ok im pullin the trigger on a2010ECM that was a 5.3 6L80E from a member on here ..
01ws6 wher e wud i look for a pin out of the ecms? Thanks.
Old May 8, 2013 | 12:59 AM
I found the pinout for 08 E38 ECM ... Cannot find the pinout for 2010 E38 ECM ... Any one kno if they are pinned the same? Or point in direction of the pinout
Old May 9, 2013 | 11:46 AM
motohead911's Avatar
I thought about doing the same thing with a new ECM but was advised against it because of all the changes to the other control systems. The new logic does not sync with the older
Old May 9, 2013 | 12:09 PM
Robert91RS's Avatar
I have 2 08-09 TCMs on the shelf (#24241890). Would this not be the easier and cheaper solution, or are you saying you would have to change the entire valve body?
Old May 9, 2013 | 02:53 PM
Cool
The diagrams i've looked at regarding tcm shows you need the valve body to go with the older tcm and newer one with the 2010 i have... so im figuring just swapping tcm out wont work ..not definite on this but what im guessing
Old May 9, 2013 | 02:58 PM
Cool
I found the pin outs for both the ECMs from 08 and 2010 and they pin exactly the same..cylinder deactivation and all also the fuse block under the hood both exactly the same .. what else wouldnt work you were advised?
Old May 9, 2013 | 04:12 PM
The OS of the two different years, and the newer one is not backwards compatible. That is what I was told so I am not 100% sure. It would make sense since there is a different part # for both ECMs. I would think in the long run it would be easier to to get a trans with te older TCM.
Old May 9, 2013 | 04:19 PM
Cool
Mmmm .. The dreaded OS ...
Old May 9, 2013 | 04:30 PM
But if i have the 2010 ecm to match the newer 2010 TCM wudnt it work?
Old May 9, 2013 | 05:05 PM
It should work between the ECM and TCM but there are a bunch of subsystems like traction control, stability, abs and most things running through the BCM. Like I said this is what I was told when I started to look into this swap. So I decided I am just going to find an older style 6l80 TCM. You may want to talk with your tuner about this.
