removing rear blocks... 2wd
buddy of mine mentioned removing blocks from the rear to lower it a little, I was going to throw on some 2" lowering shackles tomorrow, is this something I could do tomorrow also without having to have any extra hardware or anything?
ok, this may be a dumb question, I've never done any leaf spring suspension work... what is the process on this? rear on jack stands, remove bolts and what from there? JB your input would be greatly appreciated here!!
make sure there is no load on the rear end. Put jack stands on the frame of the truck, and a jack under the differential with just a pound or two of pressure supporting it. Unbolt the ubolts. You should see the differential start to drop after a while. Pretty much it, just pull the bolt out and bolt it back up. I obviously skipped a few steps, but it's a pretty damn easy task.
I figured it was about that easy, just don't wanna do anything stupid here... leaf springs make me nervous for some reason... never had a problem working on the suspension on my camaro, but the truck's just looks more intimidating... hah... we'll see how this goes!
