Remove spring leaf to lower rear?
After doing a flip kit it wont help with hieght wise because the pack is under the axle.
when you remove it before the flip kit it lowers it maybe an inch but thats only because the leaf pack is on top.
If you want to go lower put shackles on it. Easier than swaping/removing leaf springs.
I know this is an old thread but im interested to see if anyone has done this.. Im about to pull that lower (big ***) leaf and see if that smoothes the ride out a bit.. I have 4/7 and airbags and it still rides like **** but only in the back. I have streetperf drop shocks and it is bouncy as hell.. stiff legged too..
Wasnt referring to the lowering as much as i was the smoother ride.. It was my assumption that the truck would ride pretty close to stock with a flip.. however this thing rides as though it has NO SPRINGS.. only tires to give.. also it takes approximately 500 lbs to make the truck sag more than an inch. I thought perhaps i had the shackle bolts too tight and in a bind.. nope.. Thought the bags were doing it, removed them.. no diff.. thought it was the shitty shocks.. nope.. im out of options, there is no way they all ride this badly, how are you all affording the chiropractor bills..
Not a whole lot you can do but change a few things or slow down.
What kind of shocks do you have now? Brand of drop?
Drop is spindles springs up front and a simple weld on perch in the rear for a flip.. Stock springs, stock shackles..
Street Performace shocks now..
signguy62
07-27-2015 03:42 PM
