Remove Bump Stops or Get Aftermarket Ones?
Old 09-12-2012, 04:15 PM
AUTOT3K's Avatar
Lightbulb Remove Bump Stops or Get Aftermarket Ones?
hey everyone
Ive done some searching on this site, and fullsizechevy and havent come up with any answers.
I've currently got my rear end dropped 2" with shackles. I used to have it 3" and loved the looks of it but was constantly riding bump stops.
if I cut the bump stops off my frame will that give me enough clearance to have a smoother ride in the rear end or will I end up smashing axle to frame making my issue worse?
or would it be suggested to get like belltech bump stops that are shorter and I believe softer? Are there even any available (I havent found any online besides universals)?
its on my 2010 silverado so the bump stops are what looks to be welded on the frame, correct me if I'm wrong.
my only complaint is just the slightest bump and i'm riding the lumber wagon ahha, spraying my tim hortons coffee all over the place, or any weight at all and its sitting on the stops. it is a daily so I wanna try keep it somewhat practical at least for now...
thanks!
Old 09-12-2012, 06:39 PM
97aztecgt's Avatar
I've got blocks removed & shackle @ lowest setting for around 3.25" & it doesn't sit on the bump stops and rides great. Check to make sure your shackles aren't rubbing on the underside of the bed & not bump stops .
Old 09-12-2012, 06:53 PM
AUTOT3K's Avatar
Originally Posted by 97aztecgt
I've got blocks removed & shackle @ lowest setting for around 3.25" & it does sit on the bump stops and rides great. Check to make sure your shackles aren't rubbing on the underside of the bed & not bump stops .
No rubbing issues or binding or anything. I actually torqued everything on the drive on rack and re checked after a week of driving. So maybe I'm just being a baby haha. Would cutting them help at all or no?
Old 09-12-2012, 06:58 PM
97aztecgt's Avatar
If you want to just be cheap, you could cut part of them off until you got some new ones. Your shocks might be worn as well, so I'd check into that.
Registered User
Slow10's Avatar
I've got mine lowered 7 inches in the rear and cut the whole bracket and have never hit my rear end to frame
Old 09-12-2012, 07:00 PM
AUTOT3K's Avatar
Off the top of my head I can't remember what shock I got but it's the belltech street performance I believe. I tossed them in with the drop at the same time
Old 09-12-2012, 07:08 PM
texasglock23's Avatar
You are supposed to tighten it down slightly, then set it on the ground, then torque it down!
Old 09-12-2012, 07:29 PM
AUTOT3K's Avatar
I didn't set it down loose or anything just did the final torque on the drive on. I did read the instructions ha
Old 09-12-2012, 10:11 PM
Sorry, never heard of anyone running a shackle and sitting on bumpstops, even on my nbs at 4" I have about 2" before I am on mine.
Old 09-13-2012, 03:56 AM
97aztecgt's Avatar
Can you take a picture of the underside with the bump stops?
Quick Reply: Remove Bump Stops or Get Aftermarket Ones?
