Rear shock bolt size?
Old Sep 2, 2014 | 03:06 PM
chopperloco's Avatar
Default Rear shock bolt size?
I need to confirm the diameter of the rear shock bolt at the shank.
I think it is 14 mm.
Can anyone confirm?
I am installing Calvert Racing shocks,it is looking like I may have to drill out the metal bushings out a bit.
Thanks
Dom
Old Sep 2, 2014 | 06:06 PM
milkey57's Avatar
Keep this updated I have a set in my garage to install also.. Thanks
Old Sep 13, 2014 | 09:57 AM
Drilling the Calvert bushings to 14mm did the trick.
Dom
Old Sep 29, 2014 | 10:30 AM
bigsapper's Avatar
Did this actually work?
My measurements are that the threaded portion is 14mm-2.0 pitch. The shank is actually 1/2"
Having a devil of a time finding a sleeve that's correct. I'm trying to replace the bolts with true 14mm bolts, but I can't find the correct size sleeve. (14mm ID x 19mm OD)
I guess if I drilled out my 1/2" ID x 3/4" OD sleeves, that would work, but I'm trying to find an off-the-shelf solution for everyone encountering this issue. (That would be anyone installing Calvert Racing, Viking, QA1, AFCO, etc shocks with factory mounts)
Old Sep 29, 2014 | 08:02 PM
Yes it worked,they are installed.
Dom
Old Sep 29, 2014 | 08:39 PM
bigsapper's Avatar
You're a great conversationalist. Has anyone told you that?
So you don't hear any bumping/banging going over speed bumps?
Old Sep 30, 2014 | 07:41 AM
LOL,face to face you can't shut me up!
I hate typing...
I have only driven the truck a bit,it is an on-going project and not plated yet.
No issues that i can see or feel
Dom
Old Oct 26, 2014 | 01:56 AM
bigsapper's Avatar
One more question if you could answer...where did you get the drill bit?
Old Oct 26, 2014 | 09:53 AM
I actually did them on the lathe at a friends machine shop,he had the bit.
Dom
Gadgetized
Aug 21, 2020 03:14 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
