Is putting a 3000 stall on a daily driver worth it??? pros cons??
Old Nov 10, 2008 | 03:21 PM
VMax's Avatar
Default Is putting a 3000 stall on a daily driver worth it??? pros cons??
hey i have a 4l70e and i want to beef it up a bit for my cam and nitrous later down the road, what would get the best out of my transmission for a low to medium cost??
Old Nov 10, 2008 | 03:29 PM
00ChevyScott's Avatar
Wearin' da big hat
I'm putting a 3600-3800 stall in my DD truck in a month or 2, ill let you know
but
pros: more fun to drive, alot faster
con: MPG goes down
Old Nov 10, 2008 | 03:37 PM
05stepside's Avatar
when my truck was my DD i loved my 3k stall! 1st gear was useless on 20s with 3.23s. i guess 1 con would be the loss of M.P.G. but i didnt care
Old Nov 10, 2008 | 03:40 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
The TT3000 is a good all around affordable converter but if you are going to throw a big shot of juice at it you might do better with one of the other more expensive Yank or PI converters.
Start out with a shift kit and servos. Add a big transmission fluid cooler before you go and add a converter.
Old Nov 10, 2008 | 05:22 PM
Imo and I'm sure I'm not alone on this one a 3000 stall is very streetable. And you say your planning a cam swap in the future so why not run the converter now and have a little fun with it.
Old Nov 10, 2008 | 07:41 PM
Truckshop's Avatar
3000 stalls should come stock. the trucks are so much easier to drive with them. someone who drives easy wouldn't even notice a tt3000.
Old Nov 10, 2008 | 07:43 PM
circusboy's Avatar
you only loose MPG in the city
highway driving you don't know it's even there
Old Nov 10, 2008 | 07:46 PM
chevyguy7802's Avatar
You'll be just fine! Burnouts are more fun!
Old Nov 10, 2008 | 07:50 PM
I put the yanktt3000 in before the cam swap and it was hardly noticeable and didnt drop much in gas mileage. It def made a big difference and was a lot more fun to drive.
Old Nov 10, 2008 | 08:02 PM
ZR1 DREAMING's Avatar
The TT3000 is a great starter verter for a mildly cammed or stock 6.0. Your DD habits will not be affected.
