Pinon Angle Question
#29
I guess I should have said pen that goes threw the springs, when I stack the shim,helper bag bracket, thers not much left of the pen for the bracket the rear end sits in, I may can washer the pen up some from the bottom let me go look at this thing! THANKS!
#30
You're talking about the bolt that holds the leaf pack together? Your helper bag bracket goes between the leaf pack and your flip kit saddle and the bag bracket takes up half of the bolt head height so you're worried the saddle may move?
If that is the case, you shouldnt be worried. Theyre just there for rough alignment. Once you tighten the u-bolts you have 50,000+ lbs of clamping force holding everything together. My 5/8" grade 8 u-bolts have about 80,000 lbs of clamping force @ 170 ft-lbs of torque. Nothing should move once you have those u bolts torqued. Just retorque after a few hundred miles and check them periodically to make sure theyre still tight. Also make sure you're using quality u bolts and torque them down to the correct spec.
