oil pressure
Old 11-02-2009, 10:08 AM
bad intentions's Avatar
Default oil pressure
guys i have an 09 i just noticed that my oil pressure sits kinda low like around 30 or less. now my brother has an 08 and his oil pressure is around 50.
what are some issues that this might cause, and how do i fix this?
and if anyone has the same issue let me know.
Old 11-02-2009, 11:17 AM
BCchevy's Avatar
Is this at idle? My 2008 idles at around 30-33 after it has reached operating temp and at 65mph it is about 45ish. My dad's 2009 is lucky to push 40 at cruising about 30-33 at temp idling. Only difference btw the 2 trucks is mine is a 4 speed and his is a 6 speed automatic.
Old 11-02-2009, 11:26 AM
Dewey's Avatar
it can depend on the oil you're using. thinner oil yields lower oil pressure. synthetic or conventional makes a difference too.
Old 11-02-2009, 11:41 AM
well i run royal purple and yeah this is at idle and running thanks guys
Old 11-02-2009, 02:04 PM
Dewey's Avatar
I run royal p too and my pressure is just below what the conventional oil ran. i sit at about 40. i'm using 10-30, what weight are you running?
Old 11-02-2009, 04:15 PM
using 5-30
Old 11-04-2009, 02:57 PM
Dewey's Avatar
that could do it. how many miles are on the truck? i use 10 30 like i said and my pressure is normal
Texas5.3_1251
03-05-2016 08:10 PM
69z-28
09-21-2015 07:31 AM
Go5.3tt06
09-14-2015 02:11 PM
Brandonlflr12
09-08-2015 09:01 PM
Boyes50
09-08-2015 12:06 PM
Quick Reply: oil pressure
