new idea for exhaust
Old May 18, 2013 | 12:18 AM
JCunningham's Avatar
Default new idea for exhaust
I know a 4" from headers back would be best but I want 2 pipes coming out the back. What if I did a 4" from LTs through muffler then a y pipe with two 2.5" pipes coming out the back. would it defeat the purpose. Not sure if I want to do it this way or just do 3" duals.
_____
Old May 18, 2013 | 12:41 AM
ak2007r6's Avatar
Would work just fine and not affect performance at all. Do it!!
Old May 19, 2013 | 11:11 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Dual 2.5 is smaller than 4, you need dual 3 to not neck down.
Old May 19, 2013 | 11:53 PM
ok then no 2.5
Old May 20, 2013 | 06:11 AM
silver-mod-o's Avatar
Hunt&Fisherator
Run run 3" dual front to back and be done with it.
Old May 21, 2013 | 07:03 AM
shaw_426hemi's Avatar
I have 4" headers back to a Y. My Y is simply for 2 tips which are side by side out back similar to the stock location. What are your plans for muffler etc and how loud do you want it? I have catted LTs with a 4" in/out 20" case magnaflow and mine is louder than most guys would want and it droans like a beast! So my recommendation is if you go 4" do your research if you want to avoid drone, find a resonator or something and/or a longer muffler. Otherwise run dual 3" as stated, you have far more muffler choices with that route.
Old May 21, 2013 | 12:58 PM
no drone and I want to be able to talk to the person next to me with out raising my voice.
Old May 21, 2013 | 01:07 PM
_zebra's Avatar
makes children cry
necking down a little bit is fine & helps keep exhaust velocity up at the back end. have you looked at large HVAC systems? they start with large ducting close to the pump and step down smaller as it gets farther away so that the air comes out the vents at the same rate. i remember an old hotrodding article from a few years ago explaining in more technical terms how that applies to vehicles, too.
personally, i'm using a slight step-down on both my vehicles and they run & sound great. the truck has a stock 5.3 running 1.75" LTs, 2.5" Y into single 3" then through a dual-out muffler to 2.25" tails and 3.5x22" tips to deepen the sound. the car's TVS2300 LS1 @ 11psi has 1.875" LTs to 3" X and 2.5" axle-back
Old May 21, 2013 | 10:11 PM
Vdrsnk04's Avatar
Sound clip plz!!
ARC
57
Feb 21, 2022 10:54 AM
pittman
Jan 19, 2016 07:06 AM
smokeshow
Aug 23, 2015 08:23 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
