MPG just went south
Old 05-04-2019, 05:16 PM
Hunt&Fisherator
silver-mod-o's Avatar
Default MPG just went south
This is on my wife’s ‘12 Denali XL. I recently replaced the valve cover gaskets and grommets due to a leak developing on the driver side. While I was there I replaced the 130K mile plugs. We went on a road trip shortly after and averaged 16-17 on the trip loaded down running 75. Which is about average for this thing on mid-grade fuel, E85 is hard to find around here. I’ve noticed a decline lately and checked it. It’s down from 14ish around town to about 10.5. Still runs and drives fine and the only recent changes being the plugs. I installed the same TR55’s I always run in these things N/A but I’m considering going back to an OEM Delco plug and new wires. Are there any other common problem areas on the 6.2’s that cause the mileage to drop like a rock???
Old 05-04-2019, 08:56 PM
FFDP's Avatar
Can you see live data?
I'd be curious if the virtual flex fuel is stuck, causing it to burn extra fuel. Unless you installed and wired in a real sensor.
Old 05-05-2019, 08:05 AM
Hunt&Fisherator
Yeah. I’ve got HPT. Just haven’t scanned it yet.
Old 05-05-2019, 09:06 AM
madmann26's Avatar
What’s the off chance you’re getting fuel with more ethanol?
Old 05-05-2019, 04:08 PM
ZO6Ted's Avatar
Oxygen sensor? Hell idk...where's my beer now.
Old 05-06-2019, 07:13 AM
Hunt&Fisherator
Might have been a bad tank of fuel, seems to be doing better now though. It’s up to 12.5 or so. I’ll watch it over this week.
Old 05-12-2019, 09:40 AM
GMNUT's Avatar
I've never had luck with the tr55's on these trucks. I always run the iridium plugs, no messing with gap and they work awesome. ACDELCO 41162.
Old 05-12-2019, 09:55 PM
Mod with training wheels
smokeshow's Avatar
If it's stock, run stock plugs. Don't reinvent the wheel.
Old 05-16-2019, 01:15 PM
swathdiver's Avatar
Yeah, run ACDelco plugs and if the O2 sensors haven't been changed, graph them to see if any are getting lazy. My mileage went south due to bad cats. First one and then the other. No codes at first, then occasional and then all the time. Mileage came back with Magnaflow Y-Pipe and Cats. Got better with fresh O2 sensors. Improved again with drag reduction clips on the brake pads.
ridnlow
12-24-2010 11:37 PM
SS_bnoon_SS
06-03-2008 02:38 PM
slowec
12-21-2005 01:14 AM
Quick Reply: MPG just went south
