Motor mounts
I have a gauge for that
The poly mounts arent bad, most people say they cant even tell a difference except maybe at a cold start at idle. A lot has to do with tuning, as long as the engine is healthy and tuned well then vibration should be minimal. The solid mounts are typically only recommended for race only setups. Lifetime warranty too! www.atomicfp.com
I need a set of those fancy Atomic mounts..........I wish they were a bit cheaper, but I'm only going to replace these damn motor mounts one time. There is less space to work with if you have LTs.
I bought a set of Atomic motor mounts and installed them on Friday.....................best money spent.
If you're on a performance website and you're worried about a little vibration at idle.......well you're a lost cause.
