Motor mounts
How many have you broken? I’m on my second set and they are broken. Those with solid mounts, does it make your truck rough?
The poly mounts arent bad, most people say they cant even tell a difference except maybe at a cold start at idle. A lot has to do with tuning, as long as the engine is healthy and tuned well then vibration should be minimal. The solid mounts are typically only recommended for race only setups. Lifetime warranty too! www.atomicfp.com
I need a set of those fancy Atomic mounts..........I wish they were a bit cheaper, but I'm only going to replace these damn motor mounts one time. There is less space to work with if you have LTs.
Word is if you manage to break an AFP mount he will send a replacement for free AND buy you a steak dinner anywhere you want :lol:
Originally Posted by Atomic
(Post 5479661)
I bought a set of Atomic motor mounts and installed them on Friday.....................best money spent.
If you're on a performance website and you're worried about a little vibration at idle.......well you're a lost cause. |
