LS2 Intake Swap
Old Dec 30, 2010 | 11:03 AM
two-piece's Avatar
Default LS2 Intake Swap
Can I go from my 5.3 truck intake to a LS2 intake? I know I need rail and injectors and water pump.
Old Dec 30, 2010 | 11:16 AM
Preston129's Avatar
It will bolt right up. Like you said, water pump is the biggest interference. Maybe the water/steam x-over won't clear but that's an easy fix.
What makes you want to install this manifold?
Old Dec 30, 2010 | 11:29 AM
two-piece's Avatar
Straight looks, I think the ls6 flows better but the ls2 is about 1/3 of the price. But I'm very limited with my knowledge of the subject.
Old Dec 30, 2010 | 02:21 PM
Preston129's Avatar
As long as it has a cathedral port (LS2, LS6) it will bolt up fine.
Old Dec 30, 2010 | 02:47 PM
Atomic's Avatar
I have a gauge for that
I think the alternator might need to be moved too...
Old Dec 30, 2010 | 03:05 PM
Preston129's Avatar
I was trying to think of the alternator placement on mine and couldn't remember how close to the TB it is. I think on the 90mm one with the big IAC or TPS coming out the side it might not clear the alternator but the stock 87 is pretty compact...not sure though.
Old Jan 1, 2011 | 11:16 PM
two-piece's Avatar
Think Im gonna wait for a LS6.
Old Jan 2, 2011 | 08:31 AM
iamkeniff's Avatar
eh...the LS6 depending year is 3 bolt, but the one im seeing you do for "1/2 the price" is a 3 bolt which would be stupid to install on your truck.
Old Jan 2, 2011 | 09:45 AM
two-piece's Avatar
After some research I agree.
Old Jan 16, 2011 | 10:08 AM
two-piece's Avatar
So the LS2 intake is on, factory tb and water pump. I had to clearance the water pump neck just a bit. The alternator didnt need to be moved just the idler pulley. However with the alternator sitting up so high I did relocate it for looks.https://www.performancetrucks.net/fo...1&d=1295193980
Attached Thumbnails LS2 Intake Swap-img_0820.jpg   LS2 Intake Swap-img_0817.jpg
