lowering problems
Old Aug 29, 2010 | 12:17 PM
scooter k's Avatar
Old Aug 29, 2010 | 12:19 PM
scooter k's Avatar
Already running the adjustable lift shackle mount. With the mount lowest on the frame I'm still about 1 1/2 low in rear. I have it mounted where it is now because the airbags have a better chance of being long enough. They still are too short otherwise. Needs a longer shackle in rear?
Old Aug 31, 2010 | 11:13 PM
Camaro Zach's Avatar
take a pic of the helper bags and mounts as well. I would run a longer shackle and be done with it... Then space the helper bags accordingly to fit.
The picture above is mounted in the "5 inch drop orientation" you are referring to correct?
Old Sep 2, 2010 | 01:09 PM
99SLOWC5's Avatar
i have the same setup, you need to replace your stock shackles with 2 inch lowering shackles, I run a 2-5
GF spindles
GF rear shocks
flip kit
lift hangers
2inch lowering shackles
auto air bags are for towing and loads only
unloaded
loaded
Superman09
Sep 25, 2015 05:55 AM
madmann26
Sep 7, 2015 06:41 PM
xerox17
Sep 5, 2015 01:23 PM
God Made Chevy
Sep 4, 2015 12:29 AM
