wire diagram for a 60e to 80e swap on a NNBS
im doing a conversion on my buddys 07 silverado and he has an 07 nnbs silverado and wants to install a 4L80e from an 02 escalade. I have the module and everything else needed for the swap just not the wiring info for a NNBS. Any one got a link??? thanks
Formerly darynC-10/23/10
here is the steps
Wiring mods...
Remove K(orange), V(light blue), S(white), T(tan/black) and U(brown) wires from transmission connecter. Move U(brown) wire to the S location.
Front Input Speed Sensor (ISS) is made by using the orand and light blue wires. Add a VSS connector, connect orange to terminal A and light blue to terminal B. Move the low signal wire from pin 45 to location 26 in the TCM harness.
Install the front Input Speed Sensor wiring connection
Install the shift selector switch on the driver side you removed from the 60.
The factory speed sensor can plug back into the 80e tailshaft sensor
Wiring mods...
