lowering problems
Already running the adjustable lift shackle mount. With the mount lowest on the frame I'm still about 1 1/2 low in rear. I have it mounted where it is now because the airbags have a better chance of being long enough. They still are too short otherwise. Needs a longer shackle in rear?
take a pic of the helper bags and mounts as well. I would run a longer shackle and be done with it... Then space the helper bags accordingly to fit.
The picture above is mounted in the "5 inch drop orientation" you are referring to correct?
i have the same setup, you need to replace your stock shackles with 2 inch lowering shackles, I run a 2-5
GF spindles
GF rear shocks
flip kit
lift hangers
2inch lowering shackles
auto air bags are for towing and loads only
unloaded
loaded
GF spindles
GF rear shocks
flip kit
lift hangers
unloaded
loaded
Superman09
Sep 25, 2015 05:55 AM
