looking at getting an air intake for my 6.2
Old Dec 14, 2012 | 10:16 AM
  #41
Area47's Avatar
stock cam and bolt on's. the stock air box is fine. change cam, and you will end up with a flow issue.
Old Dec 14, 2012 | 11:29 AM
  #42
JCunningham's Avatar
I have a supercharger and the stock box flows fine
Old Dec 14, 2012 | 11:44 AM
  #43
Area47's Avatar
change the box out for an open element filter and watch the air flow numbers increase and power go up.
Old Dec 22, 2012 | 10:49 AM
  #44
splinter's Avatar
Originally Posted by MeanZ71
Get the airaid tube, anything else is a waste.
There is a dyno comparison thread of intakes that Justin (blackbear tuning) did and the best 2 were the airaid jr and volant, both gaining like 8 hp.
+1
Seems the inexpensive Airaid MIT stacks up pretty well on otherwise stock applications.
BBP Independent Intake Test Results
no affiliation
File Type: pdf
Old Dec 22, 2012 | 03:45 PM
  #45
CodyG's Avatar
What's on your truck? I've though about doing this...
Old Dec 24, 2012 | 09:41 AM
  #46
Area47's Avatar
right now a stock box with a drop in filter, and an mit. i haven't gotten around to changing things out yet. or just find another 10+ stock air box and modify it
Old Dec 24, 2012 | 09:45 AM
  #47
CodyG's Avatar
Okay, I was hoping to figure out how to move the maf over... :/
Old Dec 24, 2012 | 09:52 AM
  #48
Area47's Avatar
move it over to where? there is quite a bit of extra wire in the loom itself
Old Dec 24, 2012 | 09:54 AM
  #49
CodyG's Avatar
Over to the airaid tube
Old Dec 24, 2012 | 10:07 AM
  #50
Area47's Avatar
the maf is bolted to the stock air box. if you change the air box out, the company that makes the intake system has it bolted down to the same spot. you can run whatever tube you want actually. if you really wanted too, you can move the mas air to the throttle body
