long haul gearing.
Old Sep 7, 2011 | 02:40 PM
sierra69's Avatar
Exclamation long haul gearing.
ok, what gear should i install in my 07 w/t for my trip to montant from here in arizona?i curretly have 3:23s and will be hauling a 12 bolt axle and two fenders in the bed.my cruising speed will be at 70 mph. 3:73s,3:90s or 4:10?
Old Sep 7, 2011 | 02:42 PM
BrutalSierra's Avatar
Sounds like your best with your 3.23's maybe the 3.73's but the 3.90's and 4.10's will just eat gas in the highway.
Old Sep 7, 2011 | 03:27 PM
Atomic's Avatar
I have a gauge for that
stay with the 3.23s'...
Old Sep 7, 2011 | 03:57 PM
dlt76028's Avatar
3.73s
Old Sep 7, 2011 | 05:06 PM
charcoal03silvy's Avatar
keep what ya got
Old Sep 7, 2011 | 05:08 PM
sierra69's Avatar
Sounds good guys, i was thinking 3:23s for the trip,but just wanted a second opinion from you guys here.thank you!
Old Sep 7, 2011 | 05:15 PM
dlt76028's Avatar
judging by your pic, you have a crew cab, 4.8, with bigger tires, 4sp auto. You definitely need to get your rpms up on the highway. I bet it's going to downshift alot with 3.23s. depending on your tire size I still say 3.73s, to get your rpms around 1800-1900 cruising.
Old Sep 7, 2011 | 05:27 PM
sierra69's Avatar
it does downshift alot and thats what i don't want on this trip.i have a readylift 1.5 leveling kit and run 265s instead of those gimpy 245s.
Old Sep 7, 2011 | 06:27 PM
dlt76028's Avatar
A custom tune and 3.73s will help a ton.
Old Sep 7, 2011 | 06:42 PM
Mangled03gmc's Avatar
Baltimore Whore
The stock 23's would be fine on a FLAT haul, but if your running the hills it will def be doing the down shift thing alot.. 73's are a all around good gear.. Remember bigger tires is the same as a higher gear.. So if your bigger then stock tires( height) you will be in theory running a taller gear..
