lift kit
Old Apr 1, 2013 | 09:01 PM
silvy13's Avatar
Default lift kit
Hey guys I wanna lift my 2013 silverado but I wanna know Wats a good kit to use one that will give me a some what factory ride I wanna lift it 4in I've seen some is ready lift a good brand to use ...im new the the lifted truck scene so if y'all can help me out thanks
Old Apr 1, 2013 | 11:34 PM
SLCviaAK's Avatar
Two very important questions: what size tire do you want to run? And how much are you looking to spend? That will narrow down the proper kit for you.
HAMMER!'s Avatar
Plan on mudding or mall crawling?
Old Apr 2, 2013 | 12:11 AM
mattjones's Avatar
Lift Kit, Leveling Kit, Suspension Lift Kits, Truck Lift, Pitman, Idler, A-Arms, Steering, Control Arm, Trimmline, Cognito Motorsports these guys have some good products
Old Apr 2, 2013 | 11:16 AM
Smitty2000's Avatar
I would choose a proper lift kit that drops the lower a arms down and front diff, if you are 4wd, and uses spindles to make up the extra distance between the upper and lower a-arms. Any kind of coil spacer or longer coil over shock will just ride harsher because all of the suspension components will be at a harsher angle.
Old Apr 2, 2013 | 04:38 PM
silvy13's Avatar
I plan on going mudding a couple of times not that often and I would like to run 33" tires with the 4in lift kit ..its a2wd ...looking to spend less than 2k for lift kit
Old Apr 2, 2013 | 04:55 PM
Plan on some 4:56 gears also better set your budget at about 3-5k for wheels tires lift gears and labor.
Old Apr 2, 2013 | 06:23 PM
silvy13's Avatar
I wanna run 4.56 but idk how it will do with the six speed ...I know 2k is just for the lift kit ima rock the factory tires till I find a good offroad tires and rims
Old Apr 2, 2013 | 07:17 PM
It'll do just fine I have them in my truck on stock tires. 6th gear is actually usable with them. And since you have 33's or larger it reduces the actual axle ratio.
Old Apr 2, 2013 | 07:36 PM
silvy13's Avatar
Ima have to try it out soon
GXPJAY
Nov 5, 2015 06:49 AM
thunder550
Oct 8, 2015 04:53 PM
GMCSIERRA5.3
Aug 7, 2015 01:50 AM
chacho44
Aug 3, 2015 04:07 PM
Kaldar
Jul 27, 2015 06:42 PM
