How to: declad factory rims
I put this is the GMT900 section because I'm not aware of any nbs rims tht come cladded, lucky!
Now, Decladding them isn't THAT bad. Te hardest part is getting the foam that hold the cap on to the wheel, off the wheel. Here's a few steps that I did, hopefully this helps some one.
Have the tire dismounted
This helps alot!
Look behind the rim, you'll see this
This is what we are trying to get off! I find the easiest way is not to beat it off with a hammer, but use a 3 foot long 1x1 piece of wood, and put alot of pressure on the back side of the cladding. Small guys might need a friend to help, this **** is on there!
The cap will let go
And you will be left with a mess
I find a plastic scraper and rubber hammer work best, get under it and work it off
Once you get all the foam off, your left with this
From here, paint stripper does wonders!
This helps alot!
The cap will let go
Now it's your choice
You can sand them down and polish them, paint em, powder coat, whatever floats your boat! I had mine powder coated low gloss black
And your left with a sweet set of wheels for not that much change!
