Help please! 4.8 to 5.7
Old Jun 1, 2010 | 02:17 PM
allout5.3's Avatar
Default Help please! 4.8 to 5.7
i have a 08 nnbs truck with a 4.8 and i am swapping a 5.7 aluminum ls1. the 4.8 has three knock sensors and the 5.7 only has 2 knock sensors. can i delete one of them?
Old Jun 6, 2010 | 10:29 AM
gnasty1521's Avatar
You are going to need a new tune anyway. If the LS1 only has 2 then that is all the computer will have a need for. Ask again to whoever you get your tune from.
Old Jun 6, 2010 | 10:39 AM
00ChevyScott's Avatar
Wearin' da big hat
You've got a lot of reading/learning to do....
Did you not research swapping a Gen III motor into your truck (Gen IV) before you decided on doing this?
Old Jun 8, 2010 | 12:50 PM
Mark Johnson's Avatar
Hmm- these are some good things to know; swapping a GenIII block into a GenIV truck. 'cause I'm always thinkin' in the back of my mind that one day I'm gonna put an LS1 block in place of that 5.3.............
Old Jun 8, 2010 | 04:04 PM
gnasty1521's Avatar
Just bore your 5.3. To the op, there are reluctor differences, to which they make fixes. Also as stated, research will clear this up instantly. Check out LS1tech for the guys who have done this.
Old Jun 8, 2010 | 04:16 PM
iamkeniff's Avatar
to put that older motor in your truck you will have to tear the crank out and have the reluctor ring changed to a 58x and then swap front covers and cam gears. you will have to drill the side of the block to put the knock sensors in. also change the valley cover. you dont have 3 knock sensors on the 4.8 you only have 2. i feel it's worthless to swap in an LS1 in a GMT900 just grab a 6.0/6.2 for the same price and save your time of fighting the crank and other bs.
Old Jun 8, 2010 | 07:19 PM
gnasty1521's Avatar
^^^ Werd. LS1's were only potent until people figured out that the 5.3 engines could have the same power output. They are cheaper and their reluctor is the same as yours (less work). I believe it was 2005+ LQ4's and LQ9's had the 58x as well and are still cheaper than the LS1...
Old Jun 9, 2010 | 03:15 AM
iamkeniff's Avatar
the 58x reluctor wheel didnt come in on the 4.8/5.3/6.0 until the 2007 "GMT900" the 03-07classic motors still have the 24x.
if you got money to waste, just buy a LS3 427 imo. 9500 from Texas Speed
Old Jun 10, 2010 | 07:14 PM
gnasty1521's Avatar
Thanks for the correction! Learn something new everyday. I also concur on the 427. Look up Paco LS7, he will give you an idea of a 427 in a truck
AdaMax
May 16, 2016 11:35 PM
legerwn
56
Nov 15, 2015 10:21 PM
97_ek
Sep 23, 2015 09:16 PM
FormulaZR
Sep 14, 2015 05:23 PM
