help needed on wheel/tire fitment
Old Oct 24, 2012 | 01:07 PM
TheBurlyMan's Avatar
Default help needed on wheel/tire fitment
I am wanting to widen my factory gmc 20's 1.5" to make them a 20X10. Of course the extra width will be added to the inside of the wheels. First, will that fit? I have measured and it seems that is no problem. Biggest part is can i fit 315/35R20 toyo proxes on the rear without rubbing. Again this is all only on the rear tires
Old Oct 24, 2012 | 03:07 PM
Atomic's Avatar
I have a gauge for that
Pretty sure the stockers are 7.5 so you need at add 2.5 to the inside, and no, they will not fit without a spacer.
Old Oct 24, 2012 | 03:40 PM
The stock 20's measure out at 8.5" wide. Spacer as in moving the wheel further out? That might look bogus....
Plus guys here seem to fit 305/50R20 tires on factory width wheels without rubbing and that is even more confusing because thats a much taller tire...?
Old Oct 24, 2012 | 03:56 PM
Atomic's Avatar
Ah, the 16s and 17s are 7.5, I guess they changed it for the 20s. Yes, move it further out. When I had my 17s widened to 10" the rim would hit the leaf spring, not even including the tire. Width is much harder to fit than height.
Old Oct 25, 2012 | 04:12 PM
Still looking for a definitive answer on this widening of wheels and 315 tire fitment before i spend a bunch of money... Appreciate any opinions/experience
Old Oct 25, 2012 | 04:43 PM
tiffo60's Avatar
seems to me you could measure from your hub to your leafs and see how much room you have to grow?
Old Oct 25, 2012 | 04:54 PM
From the leaf spring to the factory tire edge is approx. 3in To the wheel edge is approx. 5in
Old Oct 25, 2012 | 05:06 PM
tiffo60's Avatar
sounds like you have room to grow
Old Oct 25, 2012 | 07:18 PM
62nalide's Avatar
the 315/35/20 fit without widening them
https://www.performancetrucks.net/fo...2012-a-494470/
and stock 20s are 8.5"
http://www.finishlinewheels.com/spec...28SET+of+4%29/
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
